Question about rear wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InfamousTonyTaco7714, Aug 29, 2013.
  1. Aug 29, 2013 at 11:41 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Seems like a lot to do just for a burnout.
  2. Aug 29, 2013 at 11:44 AM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    You can launch in 4- wheel they warn you not to drive in 4 wheel drive because if you do any hard full lock turns on dry pavement it binds the axles going straight you will be fine.
  3. Aug 29, 2013 at 11:46 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I agree.
  4. Aug 29, 2013 at 12:12 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    This
    Not true. As long as you are going straight you will be fine.
    To get both rears to spin, you could use some water. But if you dont have drag slicks you dont want to use water because the water will get into the tread and actually reduce traction after your burnout. Drive around the water box! The best way to drag race in a 4wd truck is 4hi. Leave it in the entire run. That is if you are spinning leaving the line in 2hi. If you arent spinning leaving the line in 2hi, there isn't any reason to use 4hi.
    If you dont care about times, and just want some sweet burnouts, use the water box, you should be able to light both.
