Question about remote line for two amps
Discussion in 'Audio & Video' started by tango down, Jun 4, 2012.
  1. Jun 4, 2012 at 6:31 PM
    tango down
    tango down [OP] Policy Ninja
    jeff
    peoples republik of IL
    12 Taco DCSB TRD Off Road
    LED interior, rail mounted ammo cans
    SO....when hooking up two amps, can I have one remote wire going from the Head unit or wherever it comes form to the first amp and then a "jumper" wire from the remote spot on Amp #1 going to the remote terminal of Amp#2?
    Would that make both amps turn on at the same time?
    Or is it better to run two remote lines, one to each amp?
    Actually, I'll be running an Audi Control unit as well, so should I run three remote lines, one to each amp (x2) and the Audio Control unit, or can I use a jumper across all three?
  2. Jun 4, 2012 at 6:33 PM
    Aw9d
    Aw9d That one guy
    The best thing to do is run the remote wire to a relay and use that to power both amps.
  3. Jun 4, 2012 at 6:44 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    You can use a remote wire to turn on both amps. You can either use a jumper or just run tow wires from the headunit and have one go to each amp. It really doesn't matter as the end result will be all of them being essentially wired in parallel anyway. You'll be fine.
  4. Jun 4, 2012 at 6:46 PM
    tango down
    jeff
    thanks guys, especially you Italyn. You know your car audio stuffs :)
