Question about replacing blown motor
Discussion in '1st Gen. Tacomas (1995-2004)' started by suprattaddict, Feb 13, 2011.
  1. Feb 13, 2011 at 11:41 AM
    suprattaddict
    suprattaddict [OP] New Member
    Norcal
    02 Tacoma 4x4
    Hey guys, I am a new member but I've always been a lurker on Tacomaworld and now I have two qustions to ask.
    I have a 2002 Toyota Tacoma 4x4 v6 manual tranny with 85k miles. The maintenence that i've done recently before the motor blew up are:
    -Replaced all fluids like Radiator, transfer-case, tranny gear fluid, and regular oil.
    -New timing-belt
    -All drive belts
    -Thermostat
    -spark plugs
    -water-pump
    All with Toyota OEM parts.
    Long story short... I was merging into the freeway and I brought the RPM up to 4.5k before shifting out of 3rd gear into 4th gear. As soon as I shifted (I did not mis-shift) into 4th, I hear clinking sound and that was when the check engine light and oil light came on. The car started to vibrate but did not die and I pulled over to shut her down. I got out of the truck and noticed a trail of oil about 50-100 feet back and a pile of oil underneath the truck. Had a guy check it out the other day and he found a hold in my block next to the passenger side motor-mount. My questions are, what could have caused it, and how could I have prevented it from happening (especially after I've done all the maintenence on it). Also, does that mean that the motor was on it's last leg?
    My other question is, I will have to replace the motor.... do I go with a low miles (approx. 45k) used motor imported from Japan, or a rebuilt one? From the information that I've gathered, most rebuilts comes with aftermarket internals? Please help and thanks in advance.
  2. Feb 13, 2011 at 2:06 PM
    suprattaddict
    Norcal
    02 Tacoma 4x4
    Have to decide by tomorrow if anyone can suggest anything.
  3. Feb 13, 2011 at 2:16 PM
    BoostingMS6
    BoostingMS6 Well-Known Member
    Alex
    El Paso, TX
    1995.5 Tacoma Xtra Cab V6
    ^^ Wow, man. I've yet to hear of that coming from a Tacoma.
    I really hope you get this issue settled. I can't help you much as I've never looked into the issue. Have you checked junk yards at all? What caused the hole?
    Free bump for the needy.
  4. Feb 13, 2011 at 5:24 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Addicted to my name I see? (suprattaddict).... :D Sorry about the truck... Probably was a lemon idk.
  5. Feb 13, 2011 at 11:53 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Did it over rev? I have only read of like two 3.4's blowing on such low miles. These motors are tanks and hardly have any problems at all. Sorry to hear about the truck. My advice is to look at junkyards and try to find one locally if you can.
  6. Feb 14, 2011 at 12:44 AM
    tlh178
    tlh178 Well-Known Member
    terry
    mich
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    if the motor with 45k on it is alot less money i would buy that one. i have 265k on mine and still sounds great.
  7. Feb 14, 2011 at 1:10 AM
    slmgt
    slmgt Well-Known Member
    Greater Seattle Area
    11 TRD Sport w/ JBL DCLB V6 AT
    Husky floor mats (Fr and Rr)
    :eek: I'd probably go with the low miles Japanese motor.
    :popcorn: sub'd because I want to know what caused this, how it could have been prevented and if Toyota CS has anything to say about it.
    Best of luck and please let us know how it turns out!
  8. Feb 14, 2011 at 4:50 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I hate to hear that about your truck! Sounds like it threw a rod through your block maybe??? But idk
    And as far as replacing the motor that's a tough call because idk how tight you are with money. One option would be just buy a block from a salvage yard and put all you old components in this "new" block, but idk how much cheaper if any this would be compared to just buying the motor you are looking at.
    Good luck
  9. Feb 14, 2011 at 8:33 AM
    suprattaddict
    Norcal
    02 Tacoma 4x4
    Thank you guys for your replies, I really appreciate it. The cost between a rebuilt motor and a low miles used one is only a few hundreds different. My only concern about a rebuilt motor is that a lot companies use very weak aftermarket internals.
    Supra TT- I am a supra addict and I am on 3rd MKIV TT.
    Everyone is telling me that the 3.4 motors are built like tanks, and that is where I am confused on how mine blew on me with such low miles and all maintenence already done?
    I was thinking that I over-reved as well but I only brought it to a max of 4.5k rpm (very few times that I've brought it this high).
  10. Feb 14, 2011 at 1:41 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    Could you buy a new block use your old internals besides new oem Toyota pistons and rods? And maybe replace your crank also? But keep your top end from your old motor? Im shocked yours blew so soon? Most 3.4 (5VZ-FE) engines make it to 250k+ easy with ZERO problems. And they are NOT driven easy. I have hit the rev limiter in mine a few times on accident when I first bought it and never had one problem with it. (knock on wood) And I have 145k and the only thing I know of that was replaced was a fuel pump. Everything else stock. But my alternator is going out now lol. But Im running alot of accesories.
  11. Feb 14, 2011 at 4:16 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    I've hit rev limited at least 5000 times on my 2.7l.No problems on the truck yet. And i've swamped the motor at least 4 times. 2.7l's are stronger than 3.4s IMO... However it'd suck to jump from a v6 to the i4 lol..
  12. Feb 14, 2011 at 4:42 PM
    BoostingMS6
    Alex
    El Paso, TX
    Even revving it occasionally all the way to 5k RPMs, that's no excuse to throw a rod (or blow your motor in any way, really).
  13. Feb 14, 2011 at 5:25 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    wow...its sad to see a low milages motor go out. i suggested to get a japanese used motor instead of rebuilt motor. better to have oem than aftermarket parts you don't know what they put in there.
  14. Feb 14, 2011 at 5:33 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    This
  15. Feb 14, 2011 at 5:45 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    2001 Tacoma 4X4 SR5 Extended Cab
  16. Feb 14, 2011 at 5:45 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Sorry to hear about this, that sucks! I doubt you could have done anything to prevent it, if it never ran low on oil then it should have lasted. One of those things in life I guess.
    If it were me I would do one of two things: either find another block and have it rebuilt by a local machine shop who will warranty their work, or get a low mileage used engine from Japan or otherwise. Hopefully, the used one will come with a decent warranty.
    I sold auto parts for several years for both NAPA and Kragen. Mass produced rebuilt engines are a real crapshoot. Just when I would think we found a good rebuilder that we could trust, I would get a warranty claim. And they were always a pain in the ass and tried to get off cheap instead of doing the right thing. In my town, the local machine shops are a crapshoot too. I wouldn't trust the one in your town unless you have multiple positive references to rely on.
    I would trust another low mileage, all factory, never been messed with engine. I see plenty of first gen trucks with tons of miles on them. I think you just got a bad one.
  17. Feb 14, 2011 at 5:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Ten years ago I had an 86 truck with a 22r that I had to replace. At the time, toyota would sell a shortblock 22r for 2,000 bucks. That's the block, crank, rods, pistons all assembled. No head or timing components. I have no idea what a 3.4 shortblock would cost if they offer it. You might check it out considering you probably have a good set of heads still. But my vote is still for a low mileage engine that hasn't been opened up or tampered with.
  18. Feb 14, 2011 at 6:03 PM
    troopa4life
    troopa4life Member
    Virginia
    02 2.7 Reg Cab 5 Speed
    Doug Thorley Shorty Headers
  19. Feb 14, 2011 at 6:04 PM
    gusotto
    gusotto gusotto
    Gary
    Iowa
    LC Engineering www.lcengineering.com has long and short blocks. Also remanufactured engines. Give them a look as they are highly regarded.
  20. Feb 15, 2011 at 4:51 PM
    Supra TT
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    Get there 1,400 HP engine :D:D:D:D
