Question about replacing leaf spring bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by jammer, Apr 28, 2017.
  1. Apr 28, 2017 at 9:48 AM
    jammer
    jammer [OP] 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    I'm planning on replacing the bushings on the leaf springs on my '03 PreRunner DBL Cab.
    A quick note..I do not live in the rust belt, and "hoping" nothing is seized.
    I'm getting confused on the front bushing replacement.
    Do you order the part high-lighted in yellow below or do you just order the left/right bushing for each side?
    Also, should I stay with the rubber bushings or switch to polyurethane? Wasn't sure if there was an advantage of one over the other for the leaf springs.
  2. Apr 28, 2017 at 3:17 PM
    jammer
    Ben
    Bentonville, AR
    Bumping this in hopes of a response
  3. Apr 28, 2017 at 3:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    If thats the part# for your year vehicle it should be that bushing. Prob same # for the opposite side in the same location. Poly is going to be stiffer if you do them all change them all to the same
  4. Apr 29, 2017 at 7:28 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I would not recommend poly, it creaks, pops and squeaks. I used this stuff from Energy called pre-lube and it helped a lot with squeaking however I still get creaking and popping. It's been a never ending battle to quiet down the rear.
  5. Apr 29, 2017 at 8:28 AM
    jammer
    Ben
    Bentonville, AR
    Thank you for the feedback
  6. Apr 29, 2017 at 9:55 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Excluding my engine, tranny & body mounts, every single bushing in my truck is Poly. I've never had any noises. The trick is to use a tacky grease when assembling and coat all surfaces the bushings have contact with.
    That said. It's a pain in the ass to convert, with the propane torches, sawzalls, files, wire brushes.... But I vote poly. They might not last as long, but if they do start to fail, replacing them is an hour job and they don't need a 20 ton press to remove THEN install. You're down half a day, not days. Just my experience..
  7. Apr 29, 2017 at 10:39 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Why are you just replacing the front bushings? Is this on stock/original leaf springs? If you are replacing the whole spring pack, I would use a bushing kit like this one: I agree with @License2Ill , poly bushings are a far superior choice. The secret to avoiding squeaky poly bushings is to use a correct lithium based lube like Red 'N Tacky from Lucas or Super Lube and to torque the bolts at ride height. Meaning, torque them with the weight of the truck on the ground.
    ready6delta likes this.
  8. Apr 29, 2017 at 10:03 PM
    col. sandurz
    col. sandurz Well-Known Member
    As others mentioned, the part in yellow is correct and should be same number for both sides.
    I put an energy suspension poly kit on mine. I've had no problems with it and haven't noticed any squeezing.
    To replace, I started with rear bushings pulling bolts, then drilled out as much rubber as possible. Torched/burned out the center piece then air-hammer the casing out. Clean with wire brush, lube up with grease and used a bearing press/c-clamp to insert.
  9. Jan 13, 2018 at 5:50 PM
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Got a set of barely used Allpro standard leafs for a good price but gonna change out the bushings. Should i just order another set of allpro bushings or is their something better like the ones listed above from wheelers? Also which bushings to use for rear as these show for the forward bushing set?
    the allpro ones didnt seem to have the center pin/sleeve just the bushings?
  10. Jan 13, 2018 at 6:05 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    I've got a set of Energy Suspension leaf spring poly bushings you can have if you pay shipping to you. I bought a master set of bushings for my 01 Taco and never used the leaf spring bushings in it as my new Allpro springs came with new ones.
    ThunderOne likes this.
  11. Jan 13, 2018 at 6:15 PM
    ready6delta
    JACOB
    Are second gen leafs the same bushing size? If so pm your info and i will paypal you man thanks.
  12. Jan 13, 2018 at 6:20 PM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    I didn't see you were a second gen. No idea but they're yours If you find out they are.
  13. Jan 13, 2018 at 6:24 PM
    ready6delta
    JACOB
    thanks i will check.
  14. Jan 13, 2018 at 6:58 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If they don't work, I'll take them. Is it the shackle and front spring eye bushings?
  15. Jan 17, 2018 at 6:12 PM
    ready6delta
    JACOB
    Looks like they are different but thanks man. Sorry didnt realize i posted in the 1st gen threads my bad.
  16. Aug 26, 2020 at 6:40 AM
    Rise007
    Rise007 Well-Known Member
    2012 white Tacoma 5 speed manual
    Does anyone know if the bushings of a first gen fit the second gen, they are cheaper and they look the same to me
  17. Aug 26, 2020 at 7:07 AM
    wcp0611
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    No, they won't.
  18. Aug 26, 2020 at 7:26 AM
    Rise007
    Thanks
  19. Aug 26, 2020 at 4:01 PM
    Rise007
    Are the rear leaf springs bushings same on a 2wd and 4wd 2012 Tacoma?....
