Question About Retrofit H1 Install
Discussion in 'Lighting' started by iJDub, Sep 3, 2013.
  1. Sep 3, 2013 at 4:30 AM
    iJDub
    iJDub [OP] Well-Known Member
    I know the H1s just "bolt in" plug and play. No real adjustment as far as horizontal levelness (unlike the FX-Rs). But I've read that some people have had level issues...so my question is: is it worth test lighting it and measuring against wall before resealing if you can't really adjust the horizontal levelness anyway? Or can you?
  2. Sep 3, 2013 at 5:10 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I would test it regardless, it has plates that keep it pretty much straight, just make sure before you reseal it that you have the projectors in straight or else your cutoff line will be like /\ instead of ---------
    Best of luck to ya!
  3. Sep 3, 2013 at 5:30 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Definitely check them against a wall before sealing them up. There is a small degree of 'play' with the horizontal adjustment with the alignment tabs. The tabs don't fit tight in the back of the headlight housing so you can rotate them slightly. In some cases, people have taken a dremel to shave the tab to allow them to rotate the projector even more in order to make them sit level (hopefully you won't have to do that step, I didn't).
  4. Sep 3, 2013 at 12:56 PM
    iJDub
    And that can only be done with the lens off correct?
