Question about retrofitting power windows?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sohum63, Mar 29, 2013.
  1. Mar 29, 2013 at 9:05 PM
    Sohum63
    Sohum63 [OP] Member
    Nor Cal
    97 tacoma 2wd and 02 tundra 4wd
    I recently got a '96 2wd tacoma to use for running around and because of the abundance of available parts and getting ideas from the Internet I started doing minor mods to it to help with comfort and to get me back into something mechanical which is what I did for a while but have not done recently.
    I want to add power windows, not very concerned with locks and really am only concerned with the passenger door at the moment. I know there are aftermarket kits that seam like they would work fine (I think an old Chevy I had my have had a set in it when I got it) and seem reasonably priced but it dosen't seem hard to find complete doors so I was wondering if retrofitting either an entire power door or the power guts would be an alternative. The electric motor looks like it will bolt right in so I was wondering if I did that what governs the motor to shut it off when reaching the top or bottom is it in the motor itself. Also, if I bolted on doors with power windows would I just need to run power to the two doors and connect them together so driver door controls passenger or is there any on board electronics I would need to add (assuming I don't worry about keyless entry).
    Thanks seams like it should be simple but I wasn't sure about a few things. Any pointers or links would be great. Mostly concerned with controlling the motor if I added it.
  2. Mar 29, 2013 at 9:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    Basically its juts a 3 way switch that tell the motor to turn on and off.
    You should be able to just swap doors or swap the internals. I did when i put a 2wd body on to my 4wd frame. All just bolted right in. But i had a wiring harness with the E windows so i didn't have to run new wires. In theory though yes you would just have to get ground and power to the motors/ switch.
    I would recomemnd if you can find some tacoma doors with them in to swap the internals or whole door. The manual opener doesnt have a good way of attacthing the motor and i doubt it would work as well as a OEM one.
    Its pretty simple to do. Power locks are a PITA to swap in and out just due to space issues.
    i have some pics..not DIY pics though..
    hmm guess i don't have that many pictures of it..sorry
  3. Mar 29, 2013 at 9:27 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I like muh manual windows.
    crank down regardless of electrical failure.
    most victims whom drown in a car...
    can't get the window down, to get out.
    or they think an air bubble is going to save them :rolleyes:
    nope
    if yer junk is going under... better get out quick
    The windows may be your only option.
    you could always invest in one of the window breaker gizmos...
    but then you might need to look for it, if it ever happened. Lol
    ^ this probably wouldn't concern city dwellers, nor desert rats...
    But those whom wheel their junk should have understanding.
    manual window crank's may be less convenient...
    but it's still the smarter choice IMO. ;)
  4. Mar 29, 2013 at 9:30 PM
    Sohum63
    Sohum63 [OP] Member
    Nor Cal
    Thanks, anybody have a good place to fing a wiring diagram showing what each wire on the door wiring harness is for.
    Thanks again, total door swap may be the way to go.
