Question about RPMs
Discussion in 'Technical Chat' started by Cloud, Jun 1, 2011.
  1. Jun 1, 2011 at 9:47 PM
    Cloud
    Cloud [OP] Member
    Florida
    2011 Tacoma 4x4 6sp V6
    Hey everyone, just got a 2011 4x4, v6, double cab, 6sp tacoma. I've never owned one before, but so far I love it. However, I noticed when I took it on the interstate, that in 6th gear at about 70-80mph the tach is at 3000rpms. That seems pretty high to me, is that normal?
  2. Jun 1, 2011 at 9:58 PM
    iliketurtles
    iliketurtles Well-Known Member
    Have the same engine and transmission and noticed the same thing with the high rpms. How's your mileage?
  3. Jun 1, 2011 at 10:12 PM
    Cloud
    Cloud [OP] Member
    Florida
    Thanks. I dont suppose there is anything that can be done to fix that? (sorry I know I'm showing my ignorance on the subject)
  4. Jun 1, 2011 at 10:14 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The 5 spd auto would be about 2500 rpm at the same speed, thanks to a taller top gear (0.72 vs 0.85 for the manual). EPA highway milage is worse for the 6-spd manual probably for this reason.
  5. Jun 1, 2011 at 10:14 PM
    Cloud
    Cloud [OP] Member
    Florida
    Not really sure of the actual mileage yet. I just filled up for the first time, got about 300 miles on a full tank.
  6. Jun 1, 2011 at 10:14 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    bigger tires will help
  7. Jun 1, 2011 at 10:19 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    x2, kind of like the gearing on a dirtbike. make the back sprocket bigger, the top speed raises with the ammunt of rpms
  8. Jun 1, 2011 at 10:21 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    larger back sprocket actually reduces the top speed and gears it down but we get the idea:p
  9. Jun 1, 2011 at 10:26 PM
    especk
    Erik
    Redding, CA
    haha true
  10. Jun 2, 2011 at 5:54 AM
    KenLyns
    Belly of the Beast
    It will take a significant jump in tire size to make up for the 18% difference in gearing between the manual and auto, like going from 31" to 37" tires. Bigger tires are heavier, so they'll offset milage gains. Going to a taller axle ratio, equivalent to a smaller wheel sprocket on a bike, has fewer drawbacks (minimal weight gain, no speedo error), but acceleration will suffer. The proper solution for Toyota is to go with a taller 6th gear or add a 7th gear.
  11. Jun 3, 2011 at 11:01 PM
    x2468
    x2468 Well-Known Member
    Vermont
    '02 TRD 4wd V6 Xcab Sr5
    seems pretty stupid that 6th gear on the manual is lower than 5th on the auto. Sounds almost like it's a close ratio tranny in the 6 speed manual? Thing must accelerate like a beast.... But for practicality they should have put 5th slightly lower than the auto 5th and then made 6th higher. I mean when i consider getting a manual tran car, the first advantage i think of is better MPG...
  12. Jun 3, 2011 at 11:03 PM
    x2468
    Vermont
    could the OP fix things by changing out the rear axle gears? or would it mess up the gaps in the lower gears?
