Question about safety during lift
Discussion in 'Suspension' started by rhowell, Jan 22, 2012.
  1. Jan 22, 2012 at 11:10 AM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Ok,
    All my parts have arrived.
    OME front and rear shocks.
    885 coils
    New Dakar leaf springs
    LR UCA
    Just waiting for the weather to warm up.
    How to you "safely" lift your truck in your driveway when working on the front? What about when working on the back?
  2. Jan 22, 2012 at 11:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    In the manual, there is a page showing Lift locations, and Jack Stand placement. If you follow that, you cant go wrong.
  3. Jan 22, 2012 at 11:13 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I'm not sure what you are getting at here. Make sure the brake is on, jack on the frame, and use jack stands. Pretty standard :notsure:
  4. Jan 22, 2012 at 11:13 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Sterling, VA
    05 tacoma ls swap twin turbo
    icon lift, total chaos control arms. ls swap twin turbo in progress.
    what he said lol :thumbsup:
  5. Jan 22, 2012 at 11:15 AM
    acdronin
    acdronin Well-Known Member
    Front: Set parking brake and chock rear wheels with adequate chocks, loosen lugs a bit on front wheels, jack up, set stands, lower onto stands but leave jack under center point.
    Rears, chock front wheels really well, make sure stands are set well because its those and the front chocks are the only things keeping the truck up and in place.
  6. Jan 22, 2012 at 11:15 AM
    Sunner
    Sunner Well-Known Member
    Dont listen to them, here you go
  7. Jan 22, 2012 at 11:17 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    96 FZJ80
    Slee, ARB, TJM
    what they said /\
    Make sure when you lift the rear, you have the fronts chocked, and good too... gravity's a bad deal.
  8. Jan 22, 2012 at 11:17 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
  9. Jan 22, 2012 at 11:20 AM
    rhowell
    Robert
    Canada
    I am going to expose myself for the newb I am. What does it mean when you say make sure the wheels are "chocked" well.
  10. Jan 22, 2012 at 11:22 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Something to resist the wheel's tendency to roll. A log or chock block.
    The black wedge shaped rubber thing is a chock block
  11. Jan 22, 2012 at 11:22 AM
    skidooman
    TJ
    Northern Nevada
    96 FZJ80
    Slee, ARB, TJM
    Actual wheel chocks are the best, usually hard plastic or rubber, but you can improvise. I've used 4x4 blocks of wood. Its just something that you stick under your tire on the downhill side so it cant roll away. Make sure its stuffed under the tire as best you can, and make sure its not something the tire will roll over. this\/ is an actual chock block.
  12. Jan 22, 2012 at 11:26 AM
    acdronin
    I would go get a pair of chock blocks, when you set them, you want to make sure they are firmly set against the tire BEFORE you jack it up, usually I give em i medium kick to make sure they wedge themselves firmly under the tire, and I usually check them after I jack it up too.
  13. Jan 22, 2012 at 11:26 AM
    acdronin
    I like these the best
  14. Jan 22, 2012 at 11:39 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    I definitely remember using a 2 ft 4x4 in between the frame the jack pad to get that added height necessary to fit an add a leaf in. That definitely wasnt the most stable way to do it. Small gust of wind......
