Question about shake/shudder when brakes applied
Discussion in '1st Gen. Tacomas (1995-2004)' started by Actionjackson, Jun 26, 2021.
  1. Jun 26, 2021 at 6:34 AM
    Actionjackson
    Actionjackson [OP] Well-Known Member
    Jack
    MA
    2004 Tacoma
    Howdy,
    Lately and getting worse, my truck shakes like a son of a gun when I apply the brakes at highway speeds. like when slowing down at an off ramp. Plenty of pad up front. Plenty of shoe out back. Its not warped rotors because no peddle pulsation - I know what that feels like and this ain't it. Almost sure it is related to the rotors some how but just looking for any comments or insights to this situation. Thanks to all who reply.
  2. Jun 26, 2021 at 6:44 AM
    1997tacomav6
    Denver
    Typically that’s a rotor or pad or combo situation causing the problem
  3. Jun 26, 2021 at 8:11 AM
    Glamisman
    Glamisman Well-Known Member
    when you dont have anyone behind you slowly pull the parking brake and feel if the truck shudders. Dont pull it and lock up the rears, keep the handle twisted so that you can release the brake. All you are doing is mechanically applying the rears only by doing this.
  4. Jun 28, 2021 at 9:38 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I developed a shudder when I applied the brakes (somewhat hard) at speeds over 60 mph. One day, right after a rather hard shudder I stopped and felt the rear rims. One of them was too hot to touch, the other was as cool as the front rims. Turns out the brake shoes on the "hot" side were constantly rubbing. I backed off the adjustment and that cured the overheating and the shudder. You might have the same problem.
  5. Jun 28, 2021 at 10:01 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I wouldn't say just because your pedal doesn't shudder (or more precisely that you don't notice the pedal shuddering) that it's NOT the rotors.
    That should be your first course of action is either get the rotors turned or replace them and properly bed them.
    Nessal and JudoJohn like this.
  6. Jun 28, 2021 at 10:03 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Shudder most always means one of two things-a warped rotor, or a sticky spot on a rotor that calls for some brake kleen. I would take it in for a brake checkup either way. Never skimp on brakes.
  7. Jun 28, 2021 at 11:22 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    X 2 on what everyone else has said. Additionally, I would inspect the front suspension components as well. Perhaps there is something loose that needs to be tightened or replaced. Could be a ball joint, A-arm bolt or bushing, could be rotors are loose.
  8. Aug 8, 2021 at 11:59 AM
    Mandapants
    Mandapants New Member
    2021 Tacoma
    Picked up my 2021 Tacoma on Friday, sitting in the service bay on Sunday because of this shudder issue. Why does this seem to be a common issue with Tacomas? Is it the use of drums?
  9. Aug 8, 2021 at 12:04 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    You don't have to feel it in the pedal for it to still be warped rotors. Could have something to do with the drums too.
    Does it pull to either side when stopping? It could also be a bearing issue although you'd likely see that without braking as well.
    Nessal likes this.
  10. Aug 8, 2021 at 12:07 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Almost certainly rotors. You probably need to have them turned or replaced, but sometimes a few aggressive brake applications will help. If you tend to drive very conservatively most of the time residue can build up on the rotors. Getting up to 45-50 mph and brake hard, just short of locking up. Repeat a few times and you might get the rotors hot enough to clean any residue off of them.
    I don't think the rear drums have anything to do with it. But I've had the issue come up more than once on my 2007.
    Nessal and RedWings44 like this.
  11. Aug 8, 2021 at 1:01 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    You're in the 1st Gen forum
    1995 - 2004
    Ask the 3rd Genners
    https://www.tacomaworld.com/forums/3rd-gen-tacomas-2016.186/
  12. Aug 8, 2021 at 1:18 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Rotors. Mine didn't pulsate at the pedal. Was due for pad and rotors anyways. Went away immediately.
