Question about shifting into highest gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by joembarry, Oct 17, 2013.
  1. Oct 17, 2013 at 11:52 AM
    joembarry
    joembarry [OP] New Member
    1995tacoma
    My Truck is a 1995 Tacoma with 230K. It runs great.
    In any kind of weather my automatic transmission will not shift itself into high gear until the truck has been running for 10 minutes or so. After that no problem. This has been happening since I've been driving the truck-almost two years... I'm selling it soon and want to be able to tell folks about the "problem". Any Ideas as to what is happening?
  2. Oct 17, 2013 at 11:59 AM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    I've never had an automatic Tacoma so I'm not sure if it had the same features of the newer auto trannys. I know on the wife's 07 Yaris it doesn't shift through the full range until warmed up. Kind of a pain but it does get the engine at operating temp faster.
  3. Oct 17, 2013 at 8:11 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    when was the last time you had the atf flushed?
    cooler in decent order? maybe syncros getting a little worn?
  4. Oct 17, 2013 at 8:33 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Do a transmission flush. Mine only does it in cold weather, which is normal. It could also be speed related, they don't shift until they get past a certain speed.
