Question About Spark Plug Torquing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Skeeter, Mar 31, 2020.
  1. Apr 1, 2020 at 7:02 AM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Those copper plugs are cheap and the job is easy. I do mine every 30k
  2. Apr 1, 2020 at 7:09 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    Why bother with a torque wrench on spark plugs tho? Thread by hand till it stops, then go maybe a 1/4 turn. You should be able to feel it get tight and know when to stop.
    Skyway and Jimmyh like this.
  3. Apr 1, 2020 at 10:23 AM
    Mr.Skeeter
    Mr.Skeeter [OP] Well-Known Member
    Northern Nevada
    2014 Regular Cab 2.7 4x4 Auto
    Ok I guess I'll just do them by hand. You might laugh but I had a spare spark plugs for my lawnmower and figured I'd practice before I attempt it again. You guys were right. You finger tighten it, use the ratchet to give it 1/4-1/2 and can feel that washer crush and seal. You guys think I should redo the plugs on my truck now or just leave it be? I know you aren't fortune tellers but you think the probability is high that I hurt the threads? It ran great on my 6 hour roadtrip today and I averaged 20 mpg.
  4. Apr 1, 2020 at 10:39 AM
    ToyoTaco25
    North Carolina
    You're probably fine then if you went on a 6 hour trip after. I wouldn't worry about it. That's just me.
  5. Apr 1, 2020 at 10:51 AM
    Chiloquin_Car_Care
    Chiloquin_Car_Care homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    nice when you find the right answer
    the above mentioned technique is the same that Ive used for 360k miles on my taco
    thanks harry!
    OP- hello from southern oregon to northern nevada!
  6. Apr 1, 2020 at 11:03 AM
    Mr.Skeeter
    Northern Nevada
    Howdy from the Elko area! Thanks and I learned an important lesson here. Hopefully I'll be good changing them I'm the future. I don't think I'm gonna even bother with a torque wrench next time. Just gonna do the 1/4 turn method. May even redo my properly cause I'm a stickler lol
  7. Apr 1, 2020 at 12:25 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    As has been pointed out antiseize is not needed on NGK and Denso plugs they have a dry coating. That being said they don't forbid the use of antiseize; both manufacturers point out that using antiseize can result in overtightening but neither points out how to compensate. You compensate by reducing torque by at least 15%.
    I have 'throwaway' HF 1/2 inch torque wrench; it's in my truck with my emergency tool kit. It works but torque value is off 5lbs under 50 ft/lbs, and 3 lbs off above 50. Take it back and get a refund if you can, or get it replaced. For a good affordable torque wrench, or any tool for that matter, look at Tekton tools.
  8. Apr 1, 2020 at 6:29 PM
    Mr.Skeeter
    Northern Nevada
    I'll have to do that then. I guess you never stop learning right? In case you didn't notice I'm still new to wrenching but really like it and want to continue to pursue it. When I do them again soon I'm gonna do it correctly. Sometimes you have to learn by failure right? Again, thanks for all the advice and support.
    ToyoTaco25 likes this.
  9. Oct 4, 2023 at 7:48 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Hilarious old thread. To new readers, just use the factory recommended plugs, in this case pt# 90919-01191, torque to13ftlbs without any anti-seize. Then move on for many years knowing they are done properly and will come out easily next time.:thumbsup:
    Chris(NJ) likes this.
  10. Oct 4, 2023 at 5:53 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    This.
  11. Oct 5, 2023 at 7:16 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Hand tight then 1/2 turn is all that is needed.
