Question about stock springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HARDSHELLTACO, Aug 5, 2009.
  1. Aug 5, 2009 at 7:21 PM
    HARDSHELLTACO
    HARDSHELLTACO [OP] HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I have already ordered replacement leafs for my truck since my stock ones are pretty much at a negative arch even with AAL. Is there a possibility that my stock coils are worn too. The reason I ask is i am replacing my front coil spacer lift with new extended struts and i dont want to put worn coils on top off new struts. Anyone had similar experience? It just seems like my truck doesn't have nearly as much lift as when i first did it. If so where do you get stock springs other than the stealership.
  2. Aug 5, 2009 at 7:42 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    get OME 880 or 881 springs. i believe that they are similiar to stock size (looked almost the same when i pulled my stock ones off and compared both) and work with bilstein shocks as well, if that is what you are using.
  3. Aug 6, 2009 at 5:38 AM
    JVTACOMA
    JVTACOMA Well-Known Member
    York, Pa
    has a lot of stock parts for your suspen. and are very good to deal with.
  4. Aug 6, 2009 at 5:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  5. Aug 6, 2009 at 6:25 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    Is there any way to tell if the stock ones are shot? I can look at the leafs and see they are crap but i didn't know about the coils.
  6. Aug 6, 2009 at 6:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You would have to take them out and measure them against a new set. I belive if they are 1/2" shorter, they are worn out. Best thing is, if you are replaceing your rear springs, go ahead and replace the fronts too.
  7. Aug 6, 2009 at 6:43 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I purchased the skyjacker 3" strut lift with new rear leafs. The shocks are not adjustable so I will have to use a stock height coil. Right? All the one's i see at wheeler's provide lift.
  8. Aug 6, 2009 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats an OEM length shock....I think they give you a spacer for the lift.
  9. Aug 6, 2009 at 7:21 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
  10. Aug 6, 2009 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Aug 6, 2009 at 7:27 AM
    SmokeyDP
    SmokeyDP Well-Known Member
    Somerville, NJ
    03 Tacoma
    I'm looking into replacing my OEM stuff too and I think my shocks have 170K on them. Might just get bilsteins and replace my springs and leafs with something OEMish since I do not want to lift it.
    My 97 sits to the left side. I measured the front springs and the front left is 1" more compressed than the right side. The back left wheel well is 1" lower than the right side too.
  12. Aug 6, 2009 at 7:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep in mind, there is much more weight on the drive side with the fuel tank, battery, etc.... Maybe consider the OME 880 springs. They should only give about 1" lift, which should be acceptable to you. :)
  13. Aug 6, 2009 at 7:32 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    I confirmed this with skyjacker, the lift comes from the new strut. My concern is, i have been running a spacer lift for over a year and it has compressed my coil springs. They also confirmed that you can only go with OE coils with this strut, so does anyone have some lightly used stock coils lying around.
  14. Aug 6, 2009 at 7:39 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    When it rains water just sits in the right side towards the cab. Here is a pic, but keep in mind that the rear bumped is dented which is why it looks crooked(I need to find a new bumper too).
  15. Aug 6, 2009 at 7:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Springs could be overly worn....
  16. Aug 6, 2009 at 8:24 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    pics of springs.
  17. Aug 6, 2009 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm....The back looks normal, the front looks shot.
  18. Aug 6, 2009 at 8:31 AM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    That pic is with absolutly nothing in the bed. As soon as i put my tools back there they look almost upside down.
  19. Aug 6, 2009 at 8:45 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Skyjacker strut lift uses the stock coils and gets preloaded by the struts that SJ includes thus giving the lift. I would find some stock used coils w/ less miles.
  20. Aug 9, 2009 at 11:53 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I had to replace my rear springs because a leaf on both sides was cracked, one side it was completely broken and only held together by the shackles. I also bought bilsteins for all 4 corners, but when all was said and done, if I'd just bought the OME kit from Wheelers Offroad I would have saved a little bit of money The OldManEmu kit has everything you need to do all 4 wheels, and the front and back will work together well.
