Question about suspension lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by sull625, Jul 2, 2015.
  1. Jul 2, 2015 at 12:10 AM
    sull625
    sull625 [OP] Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    I have a 04 DC and I am wanting to remove the infuriating spacer lift from it and replace it with a all around new suspension lift. New coilovers, shocks, leafs, shackles so on so forth. However I want to get rid of the "bro" lean in the front end and have it sit level. I am looking at getting a 3" lift. Do I need spacers up front to achieve the full 3" of lift and have it sit level? Any input is appreciated. Would anyone be able to recommend a full kit and where to purchase?
    Thanks,
    Sully
  2. Jul 2, 2015 at 12:15 AM
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
  3. Jul 3, 2015 at 5:51 AM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    Do you have a 4x4? I have icons up front however can only lift mine about 2 inches ....after tearing 3 CV boots had to lower it...
  4. Jul 3, 2015 at 6:14 AM
    sull625
    Dave
    Montana
    I do have 4x4. Sounds like you need a diff drop to maintain the lift you had.
  5. Jul 3, 2015 at 6:34 AM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    If you want help its best to provide specifics.... budget and vehicle information would be a good start :thumbsup:
  6. Jul 3, 2015 at 6:36 AM
    Toyota4x46921
    Michael
    Warner Robins, GA
    Didn't help. Its laying in the garage floor. Just read where some trucks are different than others. Guess I could look into high angle boots but its been 3 years and no tear so I will leave it be
  7. Jul 3, 2015 at 6:38 AM
    sull625
    Dave
    Montana
    Track is a 04 Double Cab 4x4 TRD with the 3.4L. I want a level sitting truck at 3" of lift. I am hoping to spend $1000 (under would be nice) and have a good ride (better than the spacer lift would be fantastic).
  8. Jul 3, 2015 at 6:47 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    sounds like the toytec kit fits right in your budget.
  9. Jul 3, 2015 at 1:11 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    X2 on lifting 3in a 4X4 , then lowering the front 1in to save the boots and I have the diff drop(ToyTech). This made the rear stick up higher than the front. I drove it for 3 or 4 years like that until I removed the Add a Leaf on the rear. Now the front is 1/2 inch higher than the back but I like it like that. I would do it again with ToyTech but would have lifted 2 in with stock boots. But I understand the need to go up 3in and just deal with the boots if you need to.
