question about suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Olson, Nov 9, 2011.
  1. Nov 9, 2011 at 10:52 PM
    Olson
    Olson [OP] Well-Known Member
    Eric
    Scottsdale, AZ
    4x4 DBL Cab TRD Sport short bed
    Front-3" Pro-Comp lift coils with ES6000 struts Rear- 1.5" AAL with Pro-Comp ES9000 K&N Intake Blacked out headlights 8k HID Headlights 8k HID Foglights Cobra CB Radio Avid Off-Road Side steps 2 Memphis Amps 2 10" JL Subs(replaced stock) 3' Whip antenna Black Plast-Dip Valence
    what should i use to make my rear suspension stiffer. As you can see in this pic with trailer and my gear in the bed it is riding slanted.. different shocks would help that or just because it is quite a bit of weight? Shocks any suggestions. current PRO-COMP ES6000
  2. Nov 9, 2011 at 10:56 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    if you haul regularly, try take a look at airbags or switch out your current leaf pack for one meant for hauling, like the all-pro expo leafs
  3. Nov 9, 2011 at 11:18 PM
    Olson
    Eric
    Scottsdale, AZ
  4. Nov 10, 2011 at 4:18 AM
    JKD
    JKD Well-Known Member
    What is the tongue weight with it set up like you have in that picture? It looks from this angle like most of the weight is in front of the trailer axles.
  5. Nov 10, 2011 at 5:29 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The rear shocks do not support weight so changing them out will not help your situation.
    Do you want lift? If so, look at those All-Pro leafs or the Dakars made by OME. If not, air bags would be a good solution if you tow frequently.
  6. Nov 10, 2011 at 6:17 AM
    Olson
    Eric
    Scottsdale, AZ
    the entire trailer was fully loaded before pic was taken... i have the couches and love seat in front... most of weight in pic was on the tongue.
  7. Nov 10, 2011 at 6:25 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Timbrens..........
  8. Nov 10, 2011 at 6:35 AM
    saugus
    saugus Well-Known Member
  9. Nov 10, 2011 at 6:46 AM
    Pugga
    Massachusetts
    F-150 Mod
    They'll work, but if your leaf pack is shot it won't help your every day ride. Also, if your leaf pack is worn out, an AAL is more of a band aid. It'll help for a while but eventually it too will flatten out. If you haul or tow frequently I would consider air bags.
    Here's a cheaper place for Timbrens :D
    http://www.wheelersoffroad.com/05uptacotimbren.htm
  10. Nov 10, 2011 at 6:46 AM
    acdronin
    acdronin Well-Known Member
    I'm running airbags from Firestone, absolutely thrilled with em, pump em up for what ever load i'm running and air em down when i'm done, not too $$, easy to put in (took me about an hour ), don't need to replace the leafs, in fact, this makes everything last much longer.
