Question about the 08 TRD
Discussion in 'Suspension' started by awoit, Jan 29, 2008.
  1. Jan 29, 2008 at 11:15 AM
    awoit
    awoit [OP] Well-Known Member
    CA
    08 TRD, SR5
    so since the TRD is already factory lifted, if I were to get a suspension lift on mine, and i wanted it 3 inches higher then wat it already is... would i need to get more then 3 inches since taking the others springs out would make the truck lower?
  2. Jan 29, 2008 at 3:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u can do either a spacer lift or a complete coil replacement lift. if u get 3" lift coil setup, it'll lift it 3" over the factory setting. it sll depends on money and what ur gonna be using the truck for
