Question about the 2GR FKS
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Oct 5, 2019.
  1. Oct 5, 2019 at 8:40 AM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    I know little about modern engine design. The only engines I’ve ever completely torn down and rebuilt are a few 22r/e’s. I’ve done head gaskets and other repairs on other engines but I’m not that experienced or knowledgeable.
    What I’m wondering is how much the power curves on this engine are dictated by physical / material design vs the pcm.
    The max torque output is north of 4800 iirc. I understand that there is variable valve timing now, which I’d guess is controlled electronically and with some type solenoid. (?) Do these engines even have cam shafts?
    When one retunes (flashes the pcm with say, ov) does it also change the timing and what would traditionally be the cam shapes?
  2. Oct 5, 2019 at 8:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    How about some good reading?
    It is way more than VVT. Add in ACIS and shitty ECU logic.
    That said, the hardware is very good. The 3mb engine tune file just sucks. The torque and MPGs that OVT finds is true revealing.
  3. Oct 5, 2019 at 8:47 AM
    Rujack
    Interesting. Octane rating 91 +. Seems to be unsettled opinion about this but there it is b&w
  4. Oct 5, 2019 at 8:51 AM
    Rujack
    I’ll have to read this when the kid (and wife) are either away or asleep.
    Basically I’m in the early stages of considering ovtune vs 4.88’s but want to understand how the tune works before I jump on that wagon.
  5. Oct 5, 2019 at 8:57 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
  6. Oct 5, 2019 at 9:00 AM
    Bishop84
    Bishop84 Well-Known Member
    Emissions dictates a lot. They don't want unburnt fuel leaving. Complete combustion with good temps is what matters.
    Tacomas challenge was underhood temps, moving the cats closer (no more manifolds) and overall emissions standards.
    Sure the 2Gr makes 310hp in Lexus, but it cant sustain that in a truck towing for 6 hours. So torque and low temps were made as a compromise.
    Junkhead likes this.
  7. Oct 5, 2019 at 9:08 AM
    ThumperJones
    ThumperJones Active Member
    Frank
    2018 TRD Off Road DCSB, MGM, Manual
    The most amazing thing about this engine.....
    How much of a fuckin turd it is in a truck.
    It makes good power, you just can't use it. I hope tuning can take care of some of that, but I'm a skeptic. I do believe a tune can make the throttle more linear (bearable) and that may be enough to make it liveable. For the money a tune costs, I hope so.
  8. Oct 5, 2019 at 9:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You want to go from 4.30s stock to 4.88? You're going to be in it for about $1,500. OVT is half that and would most likely net you an MPG bump along with torque and driveability.
    SandyTaco4x4 likes this.
  9. Oct 5, 2019 at 9:41 AM
    ThumperJones
    Frank
    Something with a decent usable torque curve. Hell a 22RE had that.
  10. Oct 5, 2019 at 9:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    OVT FOB or 2.0 Beta tunes would change your mind.
  11. Oct 5, 2019 at 9:45 AM
    Rujack
    No idea what that means
  12. Oct 5, 2019 at 9:46 AM
    Rujack
    Exactly where I’m at, I just want a better understanding as to what the tune does
    Edit: actually I’d be in for closer to $2100 for gears around here
  13. Oct 5, 2019 at 9:47 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Have you tried stepped on the skinny pedal faster and getting the engine above 3500 rpms?
    Boghog1 likes this.
  14. Oct 5, 2019 at 9:50 AM
    ThumperJones
    Frank
    I'd hope so for what it costs.
  15. Oct 5, 2019 at 9:52 AM
    Rujack
    Still have to burn up the clutch off the line though. Esp uphill.
    ThumperJones likes this.
  16. Oct 5, 2019 at 9:52 AM
    ThumperJones
    Frank
    Yeah and that jerky ass surge at about 4000 when it shoots to redline, and then shift to second and it bogs? Yeah I've tried that.
    I've also tried stepping on the pedal in second gear, and it bucks and misses and then eventually lurches on down the road.
  17. Oct 5, 2019 at 9:55 AM
    ThumperJones
    Frank
    I'm not going to derail the OPs thread further. My apologies.
    I'll be out mashing the little pedal on the right waiting for something to happen if you need me. If I do that in my junky old '85, it smoothly moves down the road. But it's Hi-Tech right?
    Peace out.
  18. Oct 5, 2019 at 10:03 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There's a ton of info on 1.05B on his website. 2.0 is even better, but no notes posted yet.
    Simply, he basically rewrites all aspects of the stock tunes.
  19. Oct 5, 2019 at 10:23 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    91 octane is needed not for the power but for the knock you would get when changing timing.
  20. Oct 5, 2019 at 10:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yet you bought it? Just to talk shit?
    Junkhead, GreyBaldTaco and tonered like this.
