Question about the Bilstein 5100
Discussion in 'Suspension' started by ReelAddict, Dec 2, 2018.
  1. Dec 2, 2018 at 4:57 PM
    ReelAddict
    ReelAddict [OP] Well-Known Member
    Rob
    Lynnwood, Washington
    2018 TACOMA TRD OFF-ROAD DBL CAB
    SUSPENSION: Bilstein B8 6112 Off-Road Suspension Kit - 47-234413 (5/4 Setting) Bilstein 600lb Front Coils Bilstein 5160 Series Shock - w/0" to 1.5" Rear Suspension Lift SPC Adjustable Upper Control Arms (SPC 25470) Wheelers Off-Road Multi-Leaf Add-A-Leaf Set - 1.5" Lift 3 Leaf Progressive Wheeler's Front Superbump Set Wheeler's Rear SuperBump Bumpstop Set Tacoma 2005-2020 Toyota 4WD - Carrier Bearing Shim Kit by Old Man Emu 2016-2020 Toyota Tacoma 4x4 (2"- 6" lift) Front Differential Drop Kit by Revtek Front Strut Mounting Kit KYB SM5640 WHEELS & TIRES: Venomrex 602 17" X 9" -12 Offset Coal Black Venomrex Red Center Cap Inlay NITTO Ridge Grappler All-Season Radial Tire-LT285/70R17 C Rated Cab Mount Chop PERFORMACE: Toyota OEM Intake Flow Accelerator Mod Toyota OEM TRD Air Filter MBRP Cat-Back Exhaust System Single Side Exit 3" Black Series Toyota TSB Software Update (Transmission) KDMAX Performance Tune LIGHTING: AUXITO H11 LED Headlight Bulbs 80W 16,000LM (High & Low Beam) Complete Interior LED Lighting Kit (Xenon White) NAKOBO White 29mm Festoon Led Bulb (Vanity Mirrors) XSPEED 7440 7441 T20 LED Light Bulbs XSPEED 921 912 906 W16W T15 LED Light Bulbs XSPEED 7443 7440 7444NA W21W T20 LED Light Bulbs CaliRaised Side Shooter Ditch Lights R4T Smoked White Grille Lights Meso Customs Ultimate Turn Signal CaliRaised LED 18W Slim Flood Work Lights (Roof Rack) DV8 Offroad BS20E100W5W BS-20 20" SL8 Slim Series LED Light Bar iJDMTOY Yellow Fog Lights CaliRaised LED 18W Slim Flood Work Lights (Bed Rack) STYLING & ACCESSORIES: TRD Pro Grille W/ OEM Garnish Sensor Cover N-Fab Textured Black Nerf Steps Coverking Neosupreme Seat Covers Full Front and Half Hood CHIPPROTECT by IDENS 30% Front Window Tint Toyota OEM TRD Skid Plate Toyota OEM Bed Mat Toyota OEM Bed Cleats Toyota OEM Door Sill Protectors Toyota OEM All-Weather Floor Mats Toyota OEM Blackout Emblem Overlay Kit Matte Black TRD Off-Road Decals Bed Net Organizer Storage Box Center Console Organizer EGR Matte Black In-Channel Vent Visors TAC Fender Flares Sprayed W/Line-X Smittybilt Smart Cover Tonneau Cover AJT Key Fob CaliRaised Low Profile Ditch Light Brackets BFP Heavy Duty Recovery Tow Hook (Painted In Super Red 2) TufSkinz Red Glove Box Insert Center Console Armrest Cover Cup and Console Liners 7" Screen Protector R4T Off-Road Badges Prinsu Design Cabrack Anti Glare Hood Vinyl Custom Rocker Panel Vinyl Mountain Graphics TacoVinyl Pro Grill Decal Pelican Vault V770 Case (2) Blacked Out Side Mirrors X-Bull Traction Board's DV8 Toyota Tacoma Center Mount Winch Capable Front Bumper OEdRo D Ring Shackles Mountain Hatch Tailgate Insert (Red) Toyota OEM Tailgate Power Lock Custom Tailgate Vinyl by IDENS Kentro License Plate Holder AJT Steering Wheel Overlay (Red) AJT Cup Holder Ring (Red) Meso Custom Door Handle Covers Prinsu Ridgeline Handles All-Pro Off-Road Bed Stiffeners Rek Gen Mud Flaps (Red Lettering) Original Quick Fists (2) 3" Quick Fist (2) RotopaX RX-DLX-PM Deluxe Pack Mount (2) RotopaX RX-1.75G Gasoline Pack RotopaX RX-2G Storage Pack First Alert Fire Extinguisher Bond LH043 Red Fiberglass Shovel Gzila Awning Mount Thule 4.5' Overcast Awning CaliRaised DItch Lights Switch CaliRaised Zombie Lights Switch Nexar NEXS1 Smart Dash Cam Ironman 4x4 Fridge Slide Frontrunner RTT Quick Release Mounts Thule X Tepui Explorer Kukenam 3 Yakima Roadshower 7G Havoc Off-Road Running Boards JoyTutus Portable Car 42 Quart Refrigerator
    I'm a new member and first-time Taco owner. I want to to make sure I do the right thing for my Tacoma. I spent a good amount of money on my new truck and the last thing I want to do is mess anything up. I will not be doing any crazy off-roading or rock climbing. I do love to hunt, hike, camp, and fish. I'm doing something outdoor related on the weekends. Only thing I will be towing is my 18.7' Duckworth Advantage, at least 3-4 times a month. I feel like what I have put together a good setup for my needs. Let me know your thoughts.
    I have decided to go with Bilstein B8 5100 Series Shocks 24-263108, OME 887 lift coils, SPC Performance 25470 UCA's. If I want a 2.25" lift in the front, at what notch do the 5100's need to set at, with this setup? If I want a 2 1/2" lift in the front, what setting will 5100's need to be?
    For the rear, I will be running Bilstein 24-186728 5100 Series Shock Absorber. I was initially going with a 1'' block lift, but after some reading, this is not the best route to go. Is there an add a leaf that will give me a 1'' lift in the rear?
  2. Dec 2, 2018 at 4:59 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    For fronts - always bottom notch with OME coils.
  3. Dec 2, 2018 at 5:03 PM
    ReelAddict
    Rob
    Thank you for the info Sig45. Got any ideas for me for the rear?
  4. Dec 2, 2018 at 5:16 PM
    Sig45
    Mark
    Maine
    Add a leaf for sure. But, I'm hardly an expert so I don't know what you would need for the 1" lift.
    I'm sure others who are much more knowledgeable will chime in.
  5. Dec 3, 2018 at 5:23 PM
    Tacoknife
    Tacoknife Well-Known Member
    Stephen
    WV
    2018 Tacoma Sport 4DLB 4x4
    DBcustomzfab Grill
    I know you said 1”. Wheelers has a 1.5” aal !!
    But you tow. And idk if this would be a good option for towing. Possibly a single aal would work better for towing!!
    ReelAddict[OP] likes this.
  6. Dec 5, 2018 at 11:07 AM
    edgerat
    edgerat Well-Known Member
    Isaac
    Olympia, WA
    Brown Tacoma
    gas and oils
    Wheelers does a single 1.5" AAL
    wirenut and ReelAddict[OP] like this.
  7. Dec 5, 2018 at 11:15 AM
    ReelAddict
    Rob
    Thank you guys for the help. I went with the 1 1/2'' Pro Comp medium AAL to go along with the Bilstein 5100's for my rear setup. That should be good for the Smittybuilt tent and Diamondback cover I will be adding in the spring and also towing my aluminum fishing boat.
  8. Dec 6, 2018 at 9:58 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    There is a lot of good info at www.headstrongoffroad.com You may not need to add upper control arms.
  9. Dec 6, 2018 at 10:05 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    X2
    call marie over at headstrong, they know their tacos!!
  10. Dec 6, 2018 at 10:07 AM
    ReelAddict
    Rob
    Thank you for the info. I'm going to check out the link now.
