Question about the brakes (Possibly just on 09's)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by techgeekwill, May 26, 2009.
  1. May 26, 2009 at 10:11 AM
    techgeekwill
    techgeekwill [OP] Well-Known Member
    Spring, TX
    18 Inferno TRD OR DCSB
    I'm just curious how many other people have this problem, and if they have found a reason/resolution yet.
    My 09 has about 3k on it, ever since I picked it up, when braking from 40-60MPH normally, there is a lot of shaking/pulsing. Now, I know how warped rotors act, and this is not it, brakes fine every other time.
    Here's the interesting part, if I shift into Neutral when braking, I do not have this problem. It appears to be getting progressively worse, which is starting to make me think this is a transmission issue. It's not axel wrap, I get that, but that happens after I've come to a complete stop.
    Anyone? I'm going to the dealer tomorrow to see about getting this fixed.
  2. May 26, 2009 at 10:26 AM
    Seagrave
    Seagrave Well-Known Member
    2009 DC LB 4x4 Sport
    i have not experienced the problem, good luck. Let us know what the results are!!!!
  3. May 26, 2009 at 10:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Where do you feel the pulseing? Floor? Steering? Brake peddle?
  4. May 26, 2009 at 10:31 AM
    techgeekwill
    Spring, TX
    The entire truck. It's hard to describe. It feels like the rotors are warped, sort of, but they aren't and I don't feel it when its in Neutral.
  5. May 26, 2009 at 10:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is interesting.....Can you place a video cammera under your truck so as to catch it on vid? Maybe see if its the drivetrain?
  6. May 26, 2009 at 10:42 AM
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    try greasing the propeller shaft(drive shaft) i heard of a couple 09 shimming because they were not grease properly
  7. May 26, 2009 at 10:42 AM
    techgeekwill
    Spring, TX
    That would be a major pain in the ass, and probably wouldn't yield very good results at 50MPH.
