Question about the taco-lean..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ensaladas, Mar 28, 2016.
  1. Mar 28, 2016 at 5:06 PM
    ensaladas
    ensaladas [OP] DarthT8er
    ‘23 Trail Edition
    Does every tacoma have the "taco-lean" post-lift? I am going to order the ¼" top-plate spacer from Headstrong either way, but I was just curious if anyone has gone ahead and installed it, only to realize that they didn't need it in the first place, providing a reverse lean :confused::D - Thanks in advance.
  2. Mar 28, 2016 at 5:09 PM
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
    You have. '15? You might not have the lean yet, but you will. It's from age of the drivers side settling due to the excess of weight (you, the driver). I suppose you could put the same amount of weight as you in the passenger seat anytime you drive to keep it settling level :laugh:
    ensaladas[QUOTED][OP] likes this.
  3. Mar 28, 2016 at 5:10 PM
    Pigpen
    Dan
    Northwest Montana
    Lean exists pre lift. Most put in the spacer during lift to solve the pre existing problem. If it already leans and you lift both sides equally, it'll still lean.
  4. Mar 28, 2016 at 6:59 PM
    ensaladas
    ‘23 Trail Edition
    lol makes sense - so i guess I won't really worry about it lol
  5. Mar 28, 2016 at 7:01 PM
    ensaladas
    ‘23 Trail Edition
    But if you're replacing the strut and coil, wouldn't that negate any "drivers side wear", or is it elsewhere.
    ManBeast likes this.
  6. Mar 28, 2016 at 7:08 PM
    ensaladas
    ‘23 Trail Edition
    i mean i know the battery, gas tank, etc is all on the drivers side - but I'm just trying to figure it out :D
  7. Mar 28, 2016 at 8:08 PM
    Pigpen
    Dan
    Northwest Montana
    Everything about the truck is a little heavier on the driver side. I noticed the lean on my 2012 in 2012, before I ever read about it. My old Nissan truck had it on the passenger side. Nothing to be concerned about, but if you're changing things you might as well even it out.
  8. Mar 28, 2016 at 8:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Lol. The so called "lean" stems from nothing more than collapsed radiator support bushings. The body leans, not the chassis itself.
    Replace those with some Energy 9.4101G Polyurethane bushings and set both sides to your desired lift, then forget about it, like forever. Don't waste your money on those BS top plate "lean correcting" spacers.
    Tac11 likes this.
  9. Apr 2, 2016 at 12:59 PM
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Do you not recommend the spacer then?
  10. Apr 2, 2016 at 1:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not at all.. what I DO recommend, however, as the real alternative and proper correction is Energy Suspension Polyurethane Bushings part number 9.4101G.
    I have a thread posted about them and it has been one long discussed over. It's here on the forum if you feel compelled to look at it.
  11. Apr 2, 2016 at 1:03 PM
    Tac11
    Luis
    Yes very, I'm about to buy my aftermarket coils and Bilstein 5100 for my 3 lift. Where's ur thread? I need to research before I buy this spacer
  12. Apr 2, 2016 at 1:04 PM
    Tac11
    Luis
    Would I need to replace both side bushings or just drivers?
  13. Apr 22, 2016 at 8:44 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Hey can you post the Link 2 the thread?
  14. Apr 22, 2016 at 9:16 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
