Question about throwing in greasable bolts on Dakar leaf pack.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodsman117, Feb 27, 2019.
  1. Feb 28, 2019 at 9:36 AM
    eon_blue
    Azusa, CA
    I used the Daystar greasable bolts/bushings kit for my 1st gen, I'm sure they make them for the 2nd gens as well
  2. Feb 28, 2019 at 9:41 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Bocsy44, Norton and GHOST SHIP like this.
  3. Feb 28, 2019 at 9:49 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I plant to get the Dobinson's pins eventually.
    I recently replaced the wheelers bushings in my Dakars with Dobinsons. I got them second hand-but new from another member so they were a lot cheaper than buying new (they're kind of expensive). Since swapping I haven't had to regrease my leaf pack or otherwise address squeaks. The bushings are noticeably different in visual comparison and have wide channels cast into them to capture more grease in the spring eye. I'll post pictures when I get home, but if you get a chance to find some Dobinsons cheap I'd recommend them. I don't know if the compound is any different, FYI and there really wasn't anything wrong with the Wheelers bushings, but I was doing a refresh on my suspension and figured I'd just swap everything out.
    geekhouse23[QUOTED] likes this.
  4. Feb 28, 2019 at 9:58 AM
    eon_blue
    Azusa, CA
    What grease do you guys use? I know Daystar has their own 'brand' grease for their bushings but I've been told any lithium based grease is good for poly bushings, I've been using that on mine and it seems to work well.
  5. Feb 28, 2019 at 10:04 AM
    GHOST SHIP
    GHOST
    I have this in my grease gun now. use it like franks red hot (put that shit on everything).
    Super Lube 41150 Synthetic Grease (NLGI 2), 14.1 oz Cartridge https://www.amazon.com/dp/B0042FG74W/ref=cm_sw_r_cp_api_i_XgcECbYSZ1VYJ
    Next cartridge will most likely be Prothane supergrease:
    Prothane 19-1751 Super Grease Tube - 14 oz. https://www.amazon.com/dp/B004JMEC0E/ref=cm_sw_r_cp_api_i_MicECb9V8PZ47
    It’s a lot more expensive but if you’ve ever worked with it it’s worth it. Super thick and doesn’t move/run/melt which means it’ll stay where you want it. It’s so thick it takes a lot more force to push it through a grease gun.
    eon_blue[QUOTED] likes this.
  6. Feb 28, 2019 at 10:26 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I have a squeeze tube of super lube in the shop for general use and love it. I did some research into grease a while back and ended up with Lukas marine. Its a calcium sulfonate base, which is typically very good against water wash out and has a very low separation value. So in theory it doesnt piss oil all over your shop floor while the grease gun hangs on the wall..
    But the biggest reason I went with a C.S. based grease is because its compatible with lithium complex greases (the standard 'red' stuff). Not all greases are compatible with other types, fyi. In this application its probably not critical, but something to consider in the future on drive shafts or other bearing surfaces. Most manufactures provide a data sheet on their grease that will list the type and some other properties. No idea what "Prothane" grease is though, that was never on any of the charts I saw.
    Below is a pretty good article (with chart at the end) about different types of grease.
    https://www.mobilindustrial.com/IND/English/Files/tt-grease-compatibility.pdf
    https://lucasoil.com/pdf/TDS_Marine_Grease.pdf
    https://lucasoil.com/pdf/TDS_Red-Tacky-Grease.pdf
  7. Feb 28, 2019 at 10:32 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Prothane is not a high speed bearing grease. Only meant for articulation joints like leaf springs, control arms, steering rack bushings, etc.
    wi_taco, DrFunker and GHOST SHIP like this.
  8. Feb 28, 2019 at 4:39 PM
    SR-71A
    Zack
    Southern Maine
    Good to know.
  9. Mar 3, 2019 at 1:41 PM
    woodsman117
    woodsman117 [OP] Well-Known Member
    2015 Barcelona Red TRD OR
    OME HD lift, HD Dakars, Duratraks, RCI IFS Skid
    Yeah, it doesn't seem to be the leaf pack itself in my case. It appears to be coming solely from the forward leaf mounts. and that's with OME bushings. Seems to resolve every time I hit it with a spray on lubricant. So I think it's the bushing face on the mount that's the problem.
  10. Mar 3, 2019 at 1:43 PM
    woodsman117
    hey, I picked up a pair of the Dobinson's greasable bolts. I'm currently running OME bushings that I installed with my Dakar pack. Would you recommend new/different bushings as well? The current ones aren't old at all. Just installed them last summer.
  11. Mar 3, 2019 at 1:45 PM
    geekhouse23
    You don't need to. They should be okay
  12. Mar 3, 2019 at 1:46 PM
    woodsman117
    I was thinking of snagging the bushings as well. Did you do greaseable pins in just the front or in the shackle as well? Also, did you swap out all 6 bushings on either side?
  13. Mar 3, 2019 at 1:48 PM
    woodsman117
    I may just try the greaseable bolts in the front first and if that doesn't work I may have to just get a Dobinson bushing kit and swap out the OME's. Hate to have to tear my rear suspension apart multiple times but worse thing that happens is I get mo betta at it :rofl:
  14. Mar 3, 2019 at 1:49 PM
    geekhouse23
    I know the dobinsons ones were recommended for the front only
  15. Mar 3, 2019 at 1:49 PM
    #35
    geekhouse23
    I can do it in my sleep haha
  16. Mar 3, 2019 at 1:51 PM
    #36
    woodsman117
    Yeah I saw that but also read somewhere they would work for the rear shackles as well.
  17. Mar 3, 2019 at 1:52 PM
    #37
    woodsman117
    Excellent haha
  18. Mar 23, 2019 at 4:27 AM
    #38
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
  19. Mar 23, 2019 at 4:55 AM
    #39
    geekhouse23
  20. Mar 23, 2019 at 5:31 AM
    #40
    Wood Butcher
    Wood Butcher Well-Known Member
    2015 Pyrite Mica Tacoma TRD OR DCSB
    Has anyone run Dobinson rear springs? How do they compare to the Dakars? It seems odd that the OME are so popular while simultaneously being noisy enough to be bothersome to many owners. Are they that much better than other options?
