Question about tire pressure on my BFG AT's
Discussion in 'Wheels & Tires' started by Taco me elmo, Sep 20, 2010.
  1. Sep 20, 2010 at 11:56 PM
    Taco me elmo
    Taco me elmo [OP] Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
  2. Sep 20, 2010 at 11:59 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    thats the max rating that the tire can handle, not the recommended. 65 and they will be overinflated causing uneven wear and will feel like youre riding on rocks. 35 is a good number, a lot of people ride with 34 psi and it varies from front to back if you want more or less
  3. Sep 21, 2010 at 8:55 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah, the tire mfr will tell you to set your pressure based on the truck owner's manual. But that 80lbs pressure is for an E tire carrying max weight which is e.g. 3200lbs PER TIRE.
    The more weight you carry, the higher pressure you need to run. When was the last time you loaded your taco down to 12,800lbs (no trailer) sitting on 4 tires? :eek:
  4. Sep 21, 2010 at 8:56 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Do the chalk test. (you can search the forums for it)
