Question about tires and possible order
Discussion in 'Discount Tire Direct' started by Killer, Jun 6, 2012.
  1. Jun 6, 2012 at 9:41 AM
    Killer
    Killer [OP] Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I have a 1998 X-Cab Tacoma TRD 4x4 that has Bilsteins 5100 on the front set at 2.5". The current tires are Maxiis Big Horns that are 32 x 11.5 x 15" on OEM 1998 rims. These tires are not hitting anything. They are getting cupped and vibrating the truck, so I am going to keep them for hunting season.
    I have recently purchased a set of 16" OEM rims off a 2010 TRD Offroad Tacoma. I would like to purchase the largest Nitto Grappler that will fit on my truck without hitting the original control arms and etc.
    What size tire do you recommend?
  2. Jun 6, 2012 at 9:43 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Im not sure the backspacing on the 2nd gen wheels but you should be able to go 255/85/16 (33" tire). I would not go 285/75/16
  3. Jun 6, 2012 at 9:56 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    The 1st Gen wheels have less BS than the 2nd Gens so you might end up rubbing the UCAs with a wide tire.
    I'm running 255/85/16 BFG KM2s on 1st Gen TRDs on my 2nd Gen.
  4. Jun 6, 2012 at 10:20 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    When i had 16x8 wheels with 4.5" backspacing and 285/75/16 tires they were rubbing the frame at full lock.
  5. Jun 7, 2012 at 8:29 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for the post.
    The 2010 TRD wheels are 7" wide with a +30mm offset (5.25" BS) which like noted above will limit how wide you can go. If you're after the Terra Grappler A/T the biggest recommended size is 265/75-16. A test fit is recommended for this set-up as tire models/sizes are just like shoes, some brands run larger while others run smaller even in the same size.
