Question about Towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bpriestley04, Feb 20, 2023.
  1. Feb 20, 2023 at 9:25 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    My 19 foot Boston Whaler fueled and loaded and trailer are closer to 4,500 pounds. I have no difficulty towing the boat cross country or pulling the boat up a ramp. I generally do not even bother to use 4WD. I have LSD and TRAC and HSA. Just put your foot on the go pedal and it will not have a problem. If the ramp is especially steep or slippery then you can use 4WD. It will not hurt the truck or the 4WD system for short use on paved surfaces, especially when they are slippery. It will not hurt the truck. Only once I can recall, on a very steep and poorly maintained ramp, I got the trailer wheels caught on the end of the paved section. I used 4WD and low range with the rear locker activated to pull the boat out of whatever hole the trailer got into. Easy.
  2. Feb 20, 2023 at 9:28 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Is yours a 4-cylinder or 6-cyclinder? Automatic or manual trans? World of difference between a 2.7L MT and 4.0L auto when trying to start w/ a load on a steep-ish slope.
  3. Feb 26, 2023 at 6:19 PM
    bpriestley04
    bpriestley04 [OP] Member
    2005 Toyota Tacoma 4 Cylinder - Manual Transmission
    Just dropping back in to thank you guys for your suggestions. Wheel chocks and 4lo was the trick, no problems whatsoever.
    Hayden334 and GilbertOz like this.
  4. Feb 27, 2023 at 6:06 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
    Good deal, Glad your Diffs and T-case didn't explode on the boat ramp :rofl::rofl:
