Question about traction control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trobo78, May 6, 2025 at 4:37 PM.
  1. May 6, 2025 at 4:37 PM
    trobo78
    trobo78 [OP] New Member
    Yesterday
    Hey everyone,
    I have a 2014 Tacoma 4x2 that was involved in a minor fender-bender a few months ago. The driver of the other car (who was drunk) turned too wide and ended up hitting the left front corner of my bumper, caving it in. My left front wheel was also hit, causing my truck to be out of alignment afterwards. I got the alignment issue fixed right away, so the truck drives great now.
    However, I can no longer turn the traction control off using the button on the dash. I can't figure out how a hit on the front wheel could affect the traction control system since it is a two-wheel-drive truck. Any thoughts? Am I missing something? Thanks.
  2. May 6, 2025 at 6:44 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So your ABS, Brake, and Traction Control lights aren't on with the engine running but the button does nothing when you press it?
    HondaGM likes this.
  3. May 6, 2025 at 6:47 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Just thinking out loud....possibly a broken/faulty ABS sensor. But then I'd expect a dash light too were that the case.
    Check all the brake lines too (hard & soft) for kinks or damage.
    Does the button do anything when pressed?
  4. May 6, 2025 at 7:42 PM
    trobo78
    Yesterday
    Dm93, The traction control light is the only light that is lit up, indicating the traction control is on. When I press the button on the dash, the light doesn't go out.
  5. May 6, 2025 at 7:43 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  6. May 6, 2025 at 7:45 PM
    trobo78
    Yesterday
    Homeline, That's interesting, I didn't know the ABS and traction control were interconnected, that's definitely something to consider I guess. No, the button doesn't appear to do anything when pressed.
  7. May 6, 2025 at 7:46 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The traction control light shouldn't normally come on when the truck is running, you need to see what code(s) you have in the ABS. My hunch would be that the steering angle sensor is out of calibration.
    HondaGM likes this.
  8. May 6, 2025 at 7:52 PM
    trobo78
    Yesterday
    Dm93, OK, that's something I'll look into. Thanks!
  9. May 6, 2025 at 8:18 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They are, Traction Control, ABS, and Stability Control all use a combination of wheel speed sensors, steering angle sensor, and accelerometers. All of which are inputs to the Skid Control ECU (ABS Module), the ABS and ECM work together to accomplish Traction and Stability Control so a fault in either the engine system (check engine light) or the ABS will disable Traction and Stability Control.
