Question about turning in 4 wheel high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Being Frank, Mar 3, 2015.
  1. Mar 3, 2015 at 5:52 PM
    #41
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Mine seems to switch in and out of 4wd better if I let off on the gas. It switches even better if I momentarily flip the gearshift into neutral.
    Don't forget to put it in 4wd through the warmer months too, but if you want to turn at the same time, try to do that on sand, gravel, or someone's lawn.
  2. Mar 3, 2015 at 5:59 PM
    #42
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    It will switch easier when moving straight and not on the gas because there's less torque on the FWD components. Stopped is even better, although sometimes you may need to move it a little.
  3. Mar 3, 2015 at 6:05 PM
    #43
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    Got my fix of smartass comments in one thread today.... awesome sauce...
  4. Mar 3, 2015 at 6:53 PM
    #44
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Man cool thread. Either you never put it in 4WD or you always have it in 4WD. I only put it in 4WD (F150) to get out of deep mud, deep sand, or to grind the gears.
  5. Mar 3, 2015 at 7:02 PM
    #45
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    W-T-F did I just read???
  6. Mar 3, 2015 at 7:05 PM
    #46
    medic2230
    Murph
    Bama! Roll Tide
    Julie?
  7. Mar 3, 2015 at 7:08 PM
    #47
    File IFR
    Central MA
    OP, here's a pic of a transfer case that just couldn't take the binding stress any longer.
  8. Mar 3, 2015 at 7:38 PM
    #48
    Being Frank
    Being Frank [OP] Member
    Mid Missouri
    2011 Tacoma Dbl cab TRD Offroad
    Thats the mod I'm shooting for. Transfer case with a display window to check wear and tear on components. Sounds like I'm on the right path :)
  9. Mar 3, 2015 at 7:42 PM
    #49
    Rebelimo
    Rebelimo Well-Known Member
    Coatesville
    08 4x4 Silver streak Limo
  10. Mar 3, 2015 at 7:43 PM
    #50
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Rubicon trail
  11. Mar 3, 2015 at 8:56 PM
    #51
    File IFR
    Central MA
    Correct. You are a modern day RainMan :D. I took it from a member that has it in his sig.
    Rubicon Jeeps.... thin walled white metal T-cases :)
  12. Mar 3, 2015 at 11:12 PM
    #52
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, it is normal under the conditions you describe. But you want to minimize the conditions.
    If It is bucking on you. Take it out of 4X4 and try to make the turn.
    If you can't get traction. Put it back in 4x4 and continue on slowly in the widest turn radius possible.
    I tried to make it simple and short for you Op.
    Some times people get carried away with details.
  13. Mar 4, 2015 at 2:15 AM
    #53
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    That would be normal.
  14. Mar 4, 2015 at 4:30 AM
    #54
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Mine too. No throttle and it shifts instantly without a clunk. On the throttle I can feel the clunk.
    In the summer I just kick it into 4 HI every time I'm on a dirt road...I figure that's enough to keep everything lubricated and keep the actuator working.
  15. Mar 4, 2015 at 6:09 AM
    #55
    Being Frank
    Mid Missouri
    I appreciate all the replies both simple and detailed.
    I teach radiology students at our hospital and I tend to get carried away with details sometimes when simple is better, but I like being thorough.
    I probably came off with this post as being a 16 y/o with their first truck and no mechanical knowledge. I'm the opposite, I've done everything from clutches, paint jobs, upper engine rebuilds, motorcycles, home repairs, wood working, etc. Just new to 4WD and wanted a definite answer for this particular vehicle.
    Thanks again for the info and the laughs :D
  16. Mar 4, 2015 at 7:02 AM
    #56
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Yikes! When you get back change all fluids and rotate your tires.:eek:
  17. Mar 4, 2015 at 7:08 AM
    #57
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    I can't stop laughing. This forum is great! Awesome sense of humor.
  18. Nov 9, 2018 at 7:00 PM
    #58
    Dcox
    Dcox Well-Known Member
    Dave
    Oregon
    2018 Tacoma Sport AC MT
    Grill swap, level, tires and wheels, bed lights, tailgate actuator
    Old thread but thought I'd be sure our 2018s have the same issue with turning in 4wd. This is my 1st 4wd since the 80s but I don't remember the F250 I learned to drive on binding like my Tacoma. That said, that F250 had the turning radius of a 747. Anyway, I was in a gravel parking lot today so I threw it into 4wd hi to lube the gears etc and the truck literally stopped moving when I turned hard to park. Obviously, the gravel wasn't loose enough but felt as if I could easily brake something if I pushed it. So to be sure, this is normal and is something we just need to avoid correct?
  19. Nov 9, 2018 at 8:04 PM
    #59
    PA452
    Western PA
    This isn't an "issue", or specific to Tacomas. It's simply part of the nature of 4WD.
    blu92in99 and Janster like this.
  20. Nov 10, 2018 at 9:45 AM
    #60
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    My F350 has such a heavy front end that the rear tires slip and you don't notice it like on a light weight truck like a taco. My diesel engine weighs over 1000lbs.
    Should see what a Subaru brat feel like on dry road. Lol
