Purpose of new UCAs with larger tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Acharenio, May 22, 2020.
  1. May 22, 2020 at 10:53 PM
    Acharenio
    Acharenio [OP] Member
    Arizona, USA
    2018 TRD Off Road
    none
    I have a 2018 trd off road with a 2inch lift, ome, i want to put 285-75-16 tires and someone told me i need to change the uca's, pardon my ignorance but what the uca's do and have to do with bigger tires, if anybody can please explain and make me understand.
    thank you so much.
  2. May 22, 2020 at 11:14 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    If fixes alignment issues caused by bigger tires and lift
    71tattooguy and whatstcp like this.
  3. May 22, 2020 at 11:39 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Allows for more caster something your stock UCAS are limited but at 2 inch of lift stock uca’s are still okay. If you want the steering wheel to feel “more heavy” less floaty or increase straight line stability at speed change them out.
    Low Ranger likes this.
  4. May 22, 2020 at 11:53 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Its going to be close with 285/75/17 you are going to need a good CMC job and pinch welds for that to clear. I have a few buddies with 3rd gens with that. Most are running closer to 3" of lift as well.
  5. May 22, 2020 at 11:56 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    You don’t need UCA’s because of tires. You need it because of the lift to get your trucks alignment back into spec.
    boston23 likes this.
  6. May 23, 2020 at 6:42 AM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    sorry, what are the CMC's?
  7. May 23, 2020 at 6:57 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Cab mount chop
  8. May 23, 2020 at 7:01 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    True but being able to push caster forward moves the tire away from the cab mount.
    Matmo215[QUOTED] likes this.
  9. May 23, 2020 at 7:08 AM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    Thank you so much
  10. May 23, 2020 at 7:08 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    High caster upper control arms and adjustable upper control arms allow you to adjust your alignment based on the new characteristics of the vehicle after being lifted. This also facilitates the fitment of larger tires by gaining positive caster and allowing you to adjust for maximum wheel fitment.
    That said other factors include CMC and wheel specs in regards to fitment so while you may have a good alignment your wheel specs may require additional modifications.
    Acharenio[OP] likes this.
  11. May 23, 2020 at 8:38 AM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yes, but it’s not required. The point I’m making is you don’t need them. Sure it helps eliminate rubbing, but sure isnt required. Some people will just trim as needed.
  12. May 23, 2020 at 4:18 PM
    Acharenio
    Arizona, USA
    2018 TRD Off Road
    none
    Thank you for the help, i understand that, i called discount tire today and ask them if there will be any problems putting that size of a tire and the guys said it should be no problem, i don't know is he said that to sale the tires or it is no problem, this days you can't trust many people all they care about is $$$$$
  13. May 23, 2020 at 4:32 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Also depending on what factory wheel you have and what offset 285s may rub the UCA.
  14. May 23, 2020 at 4:43 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    You shouldn’t ask those guys at a regular discount tire. A lot of techs don’t even know unless you go to an off-roading shop that specializes in Tacoma.
    Everyone here already covered the benefits of UCA and the reason you need it for 285/75/16.
    Those are 33s and you are going to need more than just UCA. You may need (every Tacoma is different): CMC, bend the pinch weld a bit, UCA, 3+ caster when you get alignment, a different backspacing/offset wheels.
    Those tires technically fit without doing anything, the problem is they will rub when you turn or hit a bump. It can even be as bad as just braking and your front end dips and starts rubbing.
