Question about wheel spacers....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteTacoLover, Aug 6, 2018.
  1. Aug 6, 2018 at 11:24 PM
    WhiteTacoLover
    WhiteTacoLover [OP] Well-Known Member
    2009 White Tacoma TRD
    Lots of fun stuff
    Simple question...
    I recently replaced my front wheel bearings on a 2009 Tacoma 4-door short bed TRL. I expressed my interest in wheel spacers and the mechanic said they destroy the life of bearings. Is this true? I think wheels that pop out a little look super dope and always wanted them. Between my armor, front bumper, rock sliders, leveling kit, and larger mudding wheels and tires... I've already dropped down to approximately 13 MPH... I can't afford to either loose more MPG or create more maintenance problems.
    Sooo.... what's the deal with spacers?
  2. Aug 6, 2018 at 11:29 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    it does add more stress but at this point its a trade off. I added wheel spacers recently and aside from what your asking it rubbed like crazy and that was with a cab mount chop, removed mud flabs, cut liners, mashed in pinch weld but the think that got me was it was rubbing on the cab mount which I already chopped and it was rubbing bad so I removed them.
    These were 1" Bora spacers. Maybe 1.25" would have been better. Either that or get wheels with less back spacing which essentially does the same thing.
    Are you running stock and want to add spacers or aftermarket and then spacers?
    I am also running 11-13 mpg on a good day so I feel your pain. Heavy ass tires, steel all round, lift etc will kill your mpg but thats not why we did it in the first place ya know? I wish it was better so those long wheeling trips were not so costly.
    WhiteTacoLover[OP] likes this.
  3. Aug 7, 2018 at 3:04 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your mechanic is correct.
    The farther out you move the weight away from the bearing center the more stress is placed on the bearing. A small change makes a large difference in the strain on the bearing. Spacers will greatly shorten the life of the wheel bearing. Ideally the weight is centered over the bearing.
  4. Aug 7, 2018 at 6:07 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    If you are running larger tire sizes, buying the right offset or spacers is a necessity to prevent rub. Some here have experienced wheel bearing failures even on stock wheels so it's not a guarantee stock offset will prevent failures.
    I do suggest to always go with the wheels with the right offset vs. spacers just to eliminate an extra item that can cause vibes or failure. If replacements are needed, always upgrade and never go cheap in this area especially if your truck has extra weight from aftermarket add-ons and see some offroad trails. I recommend ones from Jerseybuilt Hubs.
  5. Aug 7, 2018 at 6:36 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    My advice regarding wheel spacers: DON'T
  6. Aug 7, 2018 at 6:49 AM
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    ran them for 2 years. no issues at all. i should add also that my truck saw a lot of off road use as well when the spacers were on.
  7. Aug 7, 2018 at 7:10 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I second this.
    Also pushing your tires out past any fender flares will create maintinence hell for your paint job (and in some states is illegal).
    Plus... it looks stupid lol
    I wouldn’t do it if you don’t want to add more PITA for yourself.
  8. Aug 7, 2018 at 10:02 AM
    WhiteTacoLover
    Lots of fun stuff
    Thanks for all the advice.
    I just missed rub with my current tires... I've been driving it for years with a 1.5 leveling kit in the front and 1 in the rear. About two years ago, I pulled the kit and upgraded the front and rear shocks to Rancho's... nothing crazy like Fox.... but it was what I could afford. I didn't know about offsets, I just relied on the California wheel guy knowing exactly what my Tacos turning tolerances were.
  9. Aug 7, 2018 at 10:04 AM
    WhiteTacoLover
    Lots of fun stuff
    Are offsets the same thing as wheel spacers?
  10. Aug 7, 2018 at 10:32 AM
    reidkm
    reidkm Does lifting my truck increase my boto size?
    Reid
    Hilo, Hawaii
    2015 Tacoma, 4.0V6, 4x4 SB
    6" RC Lift Kit, Bilstein 5100 Full length shocks front and rear, OME 883 Coils, SPC UCA's, 285/70/17 Cooper STT Pro's
    Exact same thing. More offset is essentially moving the mounting point further back in the barrel of the wheel to expose more lip. A wheel spacer does the exact same thing
  11. Aug 7, 2018 at 12:33 PM
    WhiteTacoLover
    Lots of fun stuff
    Got it, thanks for the reply.
