Question about wiring tailgate bar.,
Discussion in 'Lighting' started by Logically Insane, May 28, 2010.
  1. May 28, 2010 at 3:37 PM
    Logically Insane
    Logically Insane [OP] Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    OK, I got the brake lights/turn signals/ etc all hooked up to a trailer wiring harness.. But the bar also has reverse light that has to be hooked up separately... So anyways I looked at the tail lights where the reverse lights are, and there's 2 separate wires.. ones a ground, and one is the power... right? Anyways one is red, and one is white with a black stripe... the red one should be the power.. right?
  2. May 28, 2010 at 3:40 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Should be. Toyota likes using the white/black combo as a ground
  3. May 28, 2010 at 3:40 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    You got it. On our vehicles, usually a wire with a stripe in it means that it is a negative.
  4. May 28, 2010 at 3:41 PM
    Logically Insane
    Wes
    TN --- USA
    Thanks a lot guys!
