QUESTION ANSWERED. THANKS... Do I have a problem or do I have a locker in the front?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrFixit420, Jan 23, 2020.
  1. Jan 23, 2020 at 4:08 PM
    MrFixit420
    MrFixit420 [OP] Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    Test driving for a couple weeks a 2009 TRD Off Road.
    I put it in 4 HI in the parking lot. Going straight is fine but when I turn the wheel one or the other front wheels either skids or pushes like the front wheels are locked together.
    I have never felt this before unless there was a full locker. I've welded a few rear ends in my time so I am familiar with this coming from the rear but never experienced it from the front.
    Any ideas or is there a problem???
    N-C.nebulosus likes this.
  2. Jan 23, 2020 at 4:10 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    You should never run 4wd on dry pavement. The axles will bind which is what you are experiencing and it is normal. Even without a locker.
    TnShooter and MrFixit420[OP] like this.
  3. Jan 23, 2020 at 4:11 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Is the parking lot dry? What your describing is pretty typical. I experience this alot at the ski hill on warm days where I pull into the lot in the morning when its wet and slushy and then dry by the time I leave. I park in 4wd but then start to get binding when I pull out on the dry pavement once its dried in the afternoon so I just pop it back in 2wd and I'm good to go.
    You'd KNOW it if you had a front locker - they're not exactly renowned for their turning ability on the front end.
  4. Jan 23, 2020 at 4:24 PM
    MrFixit420
    Portland Oregon
    It was wet not dry but that's not the point. Where would the binding come in on an open diff? The wheels should turn independently from each other and they don't when turned. Is it because it is not a live axle but an IFS???
    Yes I know this would happen all the time if it was a locker but I have never had a 4x4 do this before and this is not my first Taco either. That is why I am asking to see what others have noticed. With an open front where is the binding coming from? Each wheel should be able to torn individually of the other and they don't.
    Sorry not being argumentative just looking for a WHY if this is the norm.
  5. Jan 23, 2020 at 4:27 PM
    eon_blue
    Azusa, CA
    You can and will still bind on wet pavement in 4hi, especially while going slow and with good grippy tires.
    99.9% sure you don't have a front locker, Tacomas have never come with front lockers and aftermarket ones only get added into heavily built wheeling rigs. What you're experiencing is the drivetrain binding from too much front traction
    grrck and MrFixit420[OP] like this.
  6. Jan 23, 2020 at 4:29 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    That is the point. Even in the manual it says never run 4wd on pavement. Doesn't matter if its wet, moist, or dry. Only run it when off pavement
  7. Jan 23, 2020 at 4:29 PM
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
    Doesn't it lock in the middle completely ? Meaning that the rear and the front spin at the same rate, the lockers have nothing to do with it. So when you turn your back wheels are covering less distance, and your front ones a bigger distance. So something has to slip in order for that to happen, if it doesn't your truck just ends up stopping.
    mojojojo78 and MrFixit420[OP] like this.
  8. Jan 23, 2020 at 4:31 PM
    eon_blue
    Azusa, CA
    No center lock on Tacomas, only AWD and full time 4wd systems (like some 4runners amd Landcruisers) have that.
    We have a part time 4wd system meant only to be used in low traction scenarios
    MrFixit420[OP] likes this.
  9. Jan 23, 2020 at 4:32 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Because the open diffs in the front and back only allow differentiation from left to right. There is no center diff, so there can be no differentiation between the front driveshaft and the rear driveshaft. When turning, the average speed of the front two wheels is different than the average speed of the rear two wheels. Thus, to prevent binding, the wheels must either slip on the pavement or you must have a center differential.
  10. Jan 23, 2020 at 4:34 PM
    Elikk
    Eli
    So the center is allways a locked "diff" pretty much
  11. Jan 23, 2020 at 4:34 PM
    andrew61987
    This is correct.
    This is not correct, the Tacoma 4WD system is center locked 100% of the time when in 4WD. There is no way to unlock it other than shifting to 2WD.
    mojojojo78 likes this.
  12. Jan 23, 2020 at 4:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  13. Jan 23, 2020 at 4:35 PM
    jbaker1976
    jbaker1976 It's always Taco Tuesday
    East TN
    2015 DCSB OR
    Camper shell with side windoors and bed slider, JL Audio Component Door Speakers, JL Audio Stealth box, Grill Craft Grill, Husky floor liners, Hondo Radio knobs, Predator steps, Remote Start, Pop N Lock, etc...
    The binding it normal. Keep it off pavement in 4Hi or 4 Low.
    When you turn the steering wheel, one wheel is rotating faster than the other and one wheel is rotating slower than the other. The differential is trying to make them rotate at the same speed.
  14. Jan 23, 2020 at 4:37 PM
    andrew61987
    In effect, yes.
  15. Jan 23, 2020 at 4:38 PM
    eon_blue
    Azusa, CA
    It sounded like he was referring to a center differential to allow 4wd usage on pavement and other dry surfaces, which we don't have
  16. Jan 23, 2020 at 4:40 PM
    MrFixit420
    Portland Oregon
    It's not a front to back situation. The front tires are locked together like there was a locker up front when the wheel is turned.
  17. Jan 23, 2020 at 4:42 PM
    MrFixit420
    Portland Oregon
    I am talking left to right sorry. NOT center diff. Both front wheels turn at the same time like it had a front locker.
  18. Jan 23, 2020 at 4:43 PM
    andrew61987
    How can you be so sure that the front binding is due to lack of left/right differentiation and not due to lack of front/rear differentiation? They should feel basically the same.
    If you're that much in doubt, the only thing you can do is throw it in 4WD, jack up the front, and try to spin those tires.
  19. Jan 23, 2020 at 4:44 PM
    MrFixit420
    Portland Oregon
    Sorry I was not talking center diff. It is a side to side front diff situation like they were both locked together and the diff as doing nothing to compensate for the difference.
  20. Jan 23, 2020 at 4:46 PM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Might want to ask in the 3rd Gen forum they are more keen to this issue!
    MrFixit420[OP] and tcjacado like this.
