Question: atleast 4" lift in the rear
Discussion in 'Suspension' started by solus, Jul 8, 2010.
  1. Jul 8, 2010 at 8:32 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    as you know I have the RCD kit which lifts the front about 4.5"... right now I have a 4" block and the TSB leaf pack in the rear.
    I'm looking to get atleast 4" of lift in the rear without the block... what kind of setup would I need.
    I like the back to be slightly higher than the front but right now I think with the block and TSB leaf pack and natural lift height its quite a bit higher now in the rear.
    Plus I just want to get rid of the block... what do you think?
    I was thinking either:
    a custom leaf pack
    or allpro 3" leaf pack and armortech shackle flip
    I'm worried that the 3" allpro and shackle flip wont be enough lift and I'll be stuck with the BRO lean
    is there another option?
  2. Jul 8, 2010 at 8:33 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    THIS!
    if its not tall enough you can add some FJ shackles! good lift and good flexxx
  3. Jul 8, 2010 at 8:39 AM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    I should go out and measure the actual height of the rear compared to the rear...
    also, I do sometimes carry about 200-400 pounds in the bed how would the allpro leafs handle that?
  4. Jul 8, 2010 at 8:59 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    3" AP leafs, ATO shackle, plus 1" XJ shackle...SS is running it and said the flip+shackle gave him 1"
  5. Jul 8, 2010 at 3:59 PM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    i got the rcd lift and put in a wheelers aal and a toytec 1" block and am about 1" higher in the back.. i also have the tsb rear springs.
  6. Jul 8, 2010 at 4:17 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    yeah but I want to avoid a block all together
  7. Jul 8, 2010 at 9:02 PM
    David10MGM
    David10MGM Active Member
    David
    Tennessee
    10 PreRunner TRD Off Road MGM
    Camburg spindles, bilstein 5100's @ 1.75, All-pro 3in leaf, 1.5in block, 5125's
    Atlas Springs has a 4 inch leaf pack for our trucks but I don't know much about them. I saw them on topguncustomz.com. I believe they run around 500 dollars.
  8. Jul 8, 2010 at 9:06 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    What's with the fj shacle comment. How does that work out? How's the fitment and install with that? Any pictures or more info on that?
    Thanks in advance
  9. Jul 8, 2010 at 9:07 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    There is a thread on shackle flip kits. Look it up and it will show you pictures of shackles, and the shackle flip kit.
  10. Jul 8, 2010 at 9:08 PM
    JRW1223
    JRW1223 Well-Known Member
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    All Pro long travel, All Pro Front bumper, BFG 285/75/16, American Racing Ledge Wheels 16x8, Vision X 8.7" Tungsten Halogen Off Road Lights
    Try Alcan springs. They can build it to you specifications. Even if you carry 200-400 lbs in the bed. Just tell them that and they can make it.
  11. Jul 8, 2010 at 9:15 PM
    08pretaco
    Oliver
    az
    I think I know what thread your talking about and I think I just skimmed or overlooked the fj shackle part of it. Thanks for the response and I am gonna look over that thread again!
  12. Jul 8, 2010 at 9:15 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    hmm thats a good idea... I just tell them I want a leaf pack to give 4" of lift?
  13. Jul 9, 2010 at 6:03 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    I have no experience with them but Ive read that a lot on here. that they can buid some to suit your needs. I think deaver will do that same thing
  14. Jul 9, 2010 at 7:48 AM
    jhodge83
    SC
    17 XLT Sport
    i've seen things about using an XJ shackle...but nothing about an FJ shackle
  15. Jul 9, 2010 at 8:15 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
  16. Jul 9, 2010 at 3:08 PM
    solus
    solus [OP] HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    So basically, everyone is suggesting either
    a custom 4" leaf pack or 3" leafs with shackle flip and xj/fj shackles
    :confused::D
  17. Jul 9, 2010 at 3:27 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    just thought i'd chime in here.. the new design of the shackle flip will allow you to run a standard toyota shackle (just like the 1st gen tacomas) thus providing plenty of options for different length shackles... plus i will be able to cut custom ones to any length you desire so you can dial it in....
  18. Jul 9, 2010 at 5:01 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    they know their stuff
    I have a set to go with the fabtech in the garage with 200 lbs extra capacity built right in.
    just give them a call and chat
    Justin
  19. Jul 9, 2010 at 5:01 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    I am waiting patiently ;)
    Justin
  20. Jul 9, 2010 at 5:13 PM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Yeah all you tell them is that you want a 4" lift and they can make it. They will even make them to handle the additional weight that you want.
