Question before I buy a winch
Discussion in 'Off-Roading & Trails' started by ajviper7, Oct 13, 2008.
  1. Oct 13, 2008 at 4:41 PM
    ajviper7
    ajviper7 [OP] Well-Known Member
    FL Panhandle
    08 silver TRD OR 4x4 AC
    Tomorrow I am going to order my winch setup for my truck. I am going with the Warn Trans4mer and a Warn M8000. My question is, with the added weight of the winch and the mount, will I need to re-level the front end to get it back up to factory height? I'm not looking to make it perfectly level, just how it was before the winch. If I do need to re-level, would a front set of Bilstein 5100's do the trick? Thanks for any input.
  2. Oct 13, 2008 at 4:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a set of 5100's may do the trick.....but i think they would wear out pretty quick with alot of weight. you may be better off and in the long run buying a set of ome coils that will give you extra height and accomodate for the extra weight. just my thoughts.:)
  3. Oct 13, 2008 at 6:43 PM
    ajviper7
    FL Panhandle
    Thanks Tacomaman. Another question though, what is the difference between the M8000 12v and the M8000 24v? Thanks
  4. Oct 13, 2008 at 7:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    as far as winches go......honestly, im not sure.
  5. Oct 13, 2008 at 7:29 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    The difference is one is driven by a single 12 volt battery and the other is powered by 2 batteries in series or on a heavier duty application where the powerplant runs on 24 volts. Stick with the 12 volt one and you'll be fine. I would recommend though to save a little weight go with some Amsteel synthetic line. The 5/16" 100 foot is $180 and will support up to 13,700lbs. If you go that route get an aluminum hawse fairlead for it.
  6. Oct 13, 2008 at 8:02 PM
    ajviper7
    FL Panhandle
    Thanks Banshee! That helps a lot. I'll definately look into that synthetic line.:thumbsup:
  7. Oct 14, 2008 at 11:23 AM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    The bad thing is a our rigs run on 12 volts and trying to rig up a 24 volt system to power a 24 volt winch would be a task. You would have to isolate the entire vehicles electrical system before to applied power to the winch.
    Melt normal synthetic line? Where did you read that? I'll stick by this guys testimonial to Amsteel.
  8. Oct 14, 2008 at 1:09 PM
    ajviper7
    FL Panhandle
    I went down today to get a quote on the trans4mer and the M8000. The place I went to quoted out the door at $2100 with labor. Does this seem a little expensive or is it about right?
