Question concerning front bearings.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cr8ondude42, Dec 12, 2020.
  1. Dec 12, 2020 at 7:50 PM
    cr8ondude42
    cr8ondude42 [OP] New Member
    2008 Tacoma 4WD
    I recently about 3k miles ago decided to replace the front bearings on my truck myself to try and and save money. I bought this Front bearing / hub assembly (https://www.autozone.com/suspension...ing-hub-assembly-950-001/773522_1035181_22589) to replace them and did not grease them when I installed them. The bearing did not look like any bearing I have packed with grease. Did some reading and decided they were most likely already packed. I have now driven the truck approximately 3k miles and smell a burning grease smell coming from the drivers side when I get out after driving truck for more than 20 minutes. Did I mess up not greasing the bearing on the way in? or should the smell be coming from else where in the trucks engine bay?
  2. Dec 12, 2020 at 7:53 PM
    Bishop84
    Bishop84 Well-Known Member
    Inspect for cv axle grease, the bearing is sealed and you are not supposed to add any lube, theres not much inside of it.
