Question for 6 inch lift owners?
Discussion in 'Suspension' started by scottj, Oct 4, 2010.
  1. Oct 4, 2010 at 2:10 AM
    scottj
    scottj [OP] Well-Known Member
    York, PA
    12 DCSB TRD sport OME
    What carrier bearing remedy have you tried and was it successful? I have 6 inch Pro Comp. Tried 3/4 inch and 1 inch spacer supplied with kit and neither worked. I talked to Pro Comp and they want me to buy their Transmission Crossmember Drop kit part #57091B. The guy I spoke to described the vibrations I was having before I even told him and claimed the crossmember kit worked on their project Tacoma.
  2. Oct 11, 2010 at 10:49 PM
    scottj
    York, PA
    no one?????????????????????
  3. Oct 19, 2010 at 8:20 AM
    Slapps74
    Slapps74 Well-Known Member
    Thornton
    2014 FJC
    Bone stock for now!
    I have the 6" Pro Comp. I used washers to fine tune the spacing. I then had a one piece drive shaft made and that help also. But.....The problem that I was having was axle wrap.
    I have a 4" block and the AAL. I had to change the pinnion angle and go back to the stock drive shaft. I do have 5 1/2 inch springs on order from Alcan to get rid of the axle wrap caused by the block. I know this is late but hope it helps.
  4. Oct 19, 2010 at 8:36 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    I have a 1" spacer and 6" alcans springs and I still get the takeoff shutter.
    I am going to be going to a 1 piece driveshaft to hopefully cure the issue
    Justin
  5. Oct 19, 2010 at 8:54 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    Im lowering my rear to 4" with shims to get rid of my shudder.
  6. Oct 19, 2010 at 11:00 AM
    Slapps74
    Thornton
    2014 FJC
    Bone stock for now!
    Why the 1" block after the springs? I was/am (just orderd springs last week from Alcan) on the fence about how much lift in the spring to get. Does yous sit level or was that why you needed the block?
    The shutter is caused by the axle wrap and you would think that would go away with the custom springs.
    Do you know the part number on your rear shocks. And how do you like them and how do the Alcan's ride and perform?
  7. Oct 19, 2010 at 3:27 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Have someone weld on new spring perches to set the pinion angle down 2-3 degrees at ride height to help with axle wrap.
  8. Oct 20, 2010 at 9:19 AM
    scottj
    York, PA
    maybe pro comps's traction bars if you think its axle wrap. I thought it was because of the driveshaft angle on the carrier bearing.
  9. Oct 21, 2010 at 7:39 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    1" carrier drop is what I was referring too.
    My truck sits about 1/2 to 3/4 ass high with 6" springs, which is what I was going for. My Icons have settled so I could crank them up a bit to level it out if I wanted. I also have 300 lbs extra carrying capacity in my springs.
    I dont remember the P/N on my shocks, but they are Bilstein 5125s with 12" of travel. I think the bodies are a tad to long for this setup, but I havent really played with it to much. They are perfect at full droop. but I am concerned on up travel, I will have to go flex it out to find out.
    They ride ok. I think it rides better than it did stock, but I contribute most of that to the Icons.
    I still have the shutter, but the DS should fix it.
    Justin
