Question for a mechanical engineer (CAD Specific)
Discussion in 'Off-Topic Discussion' started by soggyBottom, May 2, 2021.
  1. May 2, 2021 at 6:21 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I'm not trying to be a mechanical engineer, I just enjoy designing and creating parts as a hobby. Mostly 3d printing but I have done a little using aluminum. For things like gears, I usually just integrate off the shelf parts into my creations. I have no professional experience and no education in anything CAD or mechanical engineering (I'm a software engineer). What are some general concepts that you learned in school that you feel are valuable? Safety isn't an issue here because I'm generally only working with RC cars.
  2. May 2, 2021 at 6:33 AM
    TacoDozer22
    TacoDozer22 Well-Known Member
    Greg
    Colorado
    2018 DCSB OR
    CAD specific?
    Add your filets/chamfers last. Ctrl + s a lot.
    creddington likes this.
  3. May 2, 2021 at 6:59 AM
    soggyBottom
    lol yeah thanks
  4. May 2, 2021 at 8:05 AM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Are you doing 2d or 3d? Check your units. I swap back and forth between inch and mm depending on what I'm doing. If you're doing 3d modeling learn how to use the pattern, sweep and revolve tools. They can save a ton of work vs just trying to extrude bits and pieces to make a shape.
  5. May 2, 2021 at 8:29 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    CAD is just software.
    The fundamentals behind the design are rooted in several areas of study and understanding.
    Statics
    Dynamics
    Strength of Materials
    Kinematics
    Thermodynamics
    Heat Transfer
    Machine Elements
    Fluids
    ............just a few......
    Anyone can learn to run the software. Understanding and creating a good, durable design is a different process.
    rleete likes this.
  6. May 2, 2021 at 10:27 AM
    soggyBottom
    I thought you were joking but after this king about it I don't think you are.
  7. May 2, 2021 at 10:53 AM
    TacoDozer22
    Greg
    Colorado
    2018 DCSB OR
    I mean, you asked for CAD specific tips. You didn’t mention what program or your end goal (strength, DFM, performance, DFA or anything like that) so I gave a couple tips that can be applied very broadly. There are literally thousands of books, websites and forums dedicated to CAD stuff but you kinda need to be a little more specific in what you are trying to accomplish.
    Adding your filets/chamfers last is good practice because if you need to change or add features, you’re less likely to blow up your entire model tree if these things are last
    Saving a lot is a good idea because CAD requires a lot of computer resources and sometimes you may add a feature (like a screw thread or a big pattern or big assembly) that may push your computer over the edge and crash the program. I’ve lost hours of work because I didn’t save something.
  8. May 2, 2021 at 1:46 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    We didn’t learn much in college regarding CAD... but as noted above it is more related to the function of the gears and what types of forces they will be under. These are taught in a number of the core engineering classes. You could do all this by the book (formulas etc) but you’d be there for weeks. It is more common to model it in CAD and then do some Finite Element Analysis Using those 3D models and the mechanical properties of the materials to understand what forces /stresses are within the parts. You can tweak designs from there and then build and test some prototypes. This usually gets you into the ballpark and then you can adjust smaller things as needed.
    What I’ve learned in 20 years as a biomedical engineer, at least in my experience, is that engineers don’t strive for perfection on the first round. It’s why engineers do so much testing with a high degree of statistics behind it.
    soggyBottom[OP] likes this.
  9. May 3, 2021 at 4:24 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If you’re interested in 3D printing, that thought process, for me, is different vs machining. For example, when in machining thought mode, I start with a block or round and then remove material to make an item. 3D process is all about adding material. Honestly, most of my last 30+ years has had little CAD need as that’s typically a designer’s role in the industries that I’ve worked it. Engineers focus more on finite element analysis, etc.
    Always remember: F=MA...
  10. May 4, 2021 at 7:35 PM
    soggyBottom
    I've been doing quite a bit of topology optimization in my models which I think falls under FEA. The wiki page seems to have a lot of good starting points. Thanks.
  11. Jul 21, 2021 at 11:19 PM
    jeremyspoken
    jeremyspoken New Member
    Anybody can figure out how to run the software. Understanding and making a decent, sturdy plan is an alternate cycle
  12. Jul 21, 2021 at 11:39 PM
    duckytw
    duckytw Well-Known Member
    Guess and check, then check and guess. CAD is just a way to draw up what you're already thinking but taking 20x longer to do it than pen and paper. I would say work on the pen and paper long before CAD otherwise you get sucked in.
