question for adjusting Icon coilovers.
Discussion in 'Suspension' started by bridgcat, Nov 23, 2012.
  1. Nov 23, 2012 at 2:50 PM
    bridgcat
    bridgcat [OP] Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    I want to adjust my coilovers myself rather than pay someone to do it but I dont know how to go about it. I have the spanner wrench but I need some help. Can anyone give me step by step instructions or photos on adjusting them? Thanks in advance!
  2. Nov 23, 2012 at 3:45 PM
    neonlazer
    neonlazer Mechanically Goofy
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
    There is a nut that holds the ring against the shock..then you just use the wrench to spin the ring around...jack the wheels off the ground before doing so of course :D
  3. Nov 23, 2012 at 4:00 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    There's no nut on Icons. The ring has a grub screw.
    See my picture below. The threaded ring has holes where the Icon spanner wrench inserts.
    1. Jack up the truck somewhere on the frame until both wheels are off the ground.
    2. Use a marker and draw a line on the shock body at the base of the ring, so you know how far you've cranked the ring.
    3. Loosen the grub screw with an allen key.
    4. Use the spanner wrench to turn the ring.
    5. Motion ratio between shock and wheel is approx 3:5. e.g. Cranking the ring by 0.30" changes ride height by about 0.50".
    6. Tighten the grub screw. Do not overtighten or you can mash the threads. The ring has considerable friction on its own.
    [​IMG]\\
    You bought this spanner, right?
  4. Nov 24, 2012 at 6:30 PM
    adrn1986
    adrn1986 Well-Known Member
    Adrian
    Riverside Ca
    04 Pre-Runner
    -Icon Coilovers and Bypasses -LT Front and Rear -Supercharged
    Be sure to get before and after measurements.
    -Measure center of wheel to fender at ride height.
    -Jack up the truck
    -Loosen set screw (5/32" allen)
    -Crank the coilovers
    -Put your truck back on the ground
    -Scrub out the suspension (Roll/Drive it back and forth a few times)
    -Remeasure to the same place after.
    -Repeat if necessary
    -Re-tighten set screw (bottom out screw +45 degrees)
    :thumbsup: Done :thumbsup:
    *Tips:
    -Put WD40 on the adjuster nut and cylinder threads. As well as the bottom of coil cup to make it easy to adjust (adjuster and spring will rotate together @ the coil cup/rodend)
    -Make adjustments around half tank of gas so the ride hight doesn't change too drastically from full to empty
    -Check ride height front to back AND left to right (Magnetic levels on the frame under the cab and on the front core support)
    -After market UCA owners: Check clearance between coil spring and UCA at full droop. Rotate adjuster ~90 degrees left or right to clear spring to avoid interference issues with added down travel
  5. Mar 8, 2014 at 9:48 AM
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    '12 TRD Sport Upgrade, Leather, Moonroof, ICON Stage 5
    TRD Supercharger, TRD exhaust, OEM roof rack, aluminum skid plate, Access tonneau cover, Weathertechs, Tacoma bed mat, OEM black tube steps, Inalfa 925 power moonroof, Katzkin two leather heated, embroidered seats, Icon Stage 5
    Is there a certain amount of coilover adjustment that would require an alignment to be done or would it not be affected?
  6. Mar 9, 2014 at 3:32 PM
    LTDSC
    LTDSC Trophy Van
    Sam
    NorCal
    i cranked a full turn on my WE coilovers and it barely made a change. not worth to re-align if you dont have free alignments.
