Question for all electronic gurus
Discussion in 'Technical Chat' started by DWreck, May 11, 2012.
  1. May 11, 2012 at 8:15 PM
    DWreck
    DWreck [OP] Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Since building my front bumper, I have hooked up to a few trailers. Getting out and judging distance from ball to tongue, over and over, is rather annoying. Has anyone thought of a way to add a camera in the front?
    I would like to install a camera so I can have a similar viewpoint as rear when hooking up a trailer. I would like to be able to use the same screen, in the rearview mirror. I would like cameras on a toggle, front/rear.
    Any information would be great. If you are an electronics expert and can figure this out, feel free to investigate. :D
    Thanks in advance!
  2. May 12, 2012 at 4:51 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Sounds like you would need the same wires that run to the rear camera to run to the front. The wire that sends the video back can be hooked up on a switch to direct the camera you want back to the screen. Maybe radio shack sells a switch to help you with that.
  3. May 12, 2012 at 5:07 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Connect both cameras to the video display at the same input. Install a three position switch that sends power to the front camera in one position and the rear in the other and is off in the center position. Since only one camera is on at any given time this should work and be the cheapest way to do it.
  4. May 12, 2012 at 7:30 AM
    DWreck
    Derek
    Las Vegas, NV
    Thanks!
    Here's one problem, I don't have the time to chase wiring or anything like that. :D
  5. May 14, 2012 at 12:49 PM
    SampleFool
    Ga
    Silver
    08 off-road
    I thought I had the right idea going.
  6. May 29, 2012 at 7:53 AM
    1C271
    1C271 Well-Known Member
    Tennessee
    2007 4x4 TRD Off Road
    You will not be able to connect 2 camera feeds to the same input. Its not a simple wire and the cable that feeds the signal is not multiplex so it will not carry additional signal input.
    Add a second rear view mirror, ha
