Question for Bushwacker Fender flare owners
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Aug 25, 2017.
  1. Aug 25, 2017 at 1:32 PM
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    People that have installed buchwackers;
    1)is every silver exterior bolt fake?
    2)does it use ANY of the stock snap clips/ or snap clip locations?
    From what I can gather in their black and white instruction guide, It looks like all mounting bolts are along the inside perimeter.(if this is the case, They will not mount on my truck because that part has been cut out)
    example:
    Thanks in advance!
  2. Aug 25, 2017 at 3:28 PM
    MESO
    State of Jefferson
    Anyone? I guess what I am asking is;
    If i cut them at the red dotted line.... WILL THEY STILL MOUNT UP?
    Tacomamike mike likes this.
  3. Aug 25, 2017 at 3:29 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    @Danactive has these. Has a buildnthread too.
    Danactive likes this.
  4. Aug 25, 2017 at 3:30 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Interested in finding out too .
  5. Aug 25, 2017 at 3:32 PM
    MESO
    State of Jefferson
    Thanks checking it now.
    Call me crazy... take $500 brand new flares and start cutting them up..
    Just want to know how they mount before I make the plunge
  6. Aug 25, 2017 at 3:38 PM
    GPsevinSixx
    Ros Angerus
    You are crazeeee!!!
    You already buy brand new light assemblies and cut into them for your LED madness...:rofl::fistbump:
  7. Aug 25, 2017 at 3:48 PM
    Danactive
    Danactive Instagram: xxdanactivexx
    Dan
    Upstate New York
    2016 MGM TRD Sport 4x4 DCSB
    Check Out My Build Thread :)
    So... there's a few things to go over and i'll try to make this as simple as possible without making myself sound like an idiot lol
    A. the bushwacker flares are indeed "pocket" flares and the bolts are just for looks aka they bolt in a few locations to the inner fender area using a couple oem bolt/screw locations as well as a couple brackets they provide.
    B. I don't believe bushwacker is ever going to create a true cut away flare like they have in the past due to the design/style they currently have/demand for cutaway isn't high enough to produce mass quantities.
    C. like a member on here (can't remember his name unfortunately) and a lot of 2GEN guys have made the bushwacker pocket flares into actual cut away flares. I believe this is the route you would be taking... you will obviously trim the pocket flare according to the specs you require like the red dotted line area you showed above... then using your own hardware and spacers would trim and mount the cut up flares onto the fender with the bolt holes making them now true cutaway flares. DEFCONBRIX is the main person I know that has done this to a set of pocket flares and I believe he has some info on it in his build thread somewhere...
    hope this helps!
    GPsevinSixx likes this.
  8. Aug 25, 2017 at 3:49 PM
    Danactive
    Dan
    Upstate New York
    I had mine on the truck for a couple months and then chopped off a quarter of each front flare for my CBI T3 bumper lol its scary at first but from experience always start with small cuts and work your way down to the final measurement lol
    MESO[QUOTED][OP] and GPsevinSixx like this.
  9. Aug 25, 2017 at 3:52 PM
    MESO
    State of Jefferson
    Thank you for the clarification!
    I was 99% sure just wanted to make sure. According to the directions, ALL mounting screws go up from the inside. IF I cut them away...all these mounting points would be gone. Thus, would need to drill holes into the fenders and use real nuts/bolts and mount them up
    Chopping the front corner is scary, but I'm not concerned about that. I want to cut 2" around the whole thing, which I think will eliminate the mounting points.
    Danactive[QUOTED] likes this.
  10. Aug 25, 2017 at 3:56 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
  11. Aug 25, 2017 at 3:58 PM
    MESO
    State of Jefferson
    downhillbik3r[QUOTED] likes this.
