question for experts in stick shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by predental, Feb 17, 2009.
  1. Nov 12, 2009 at 11:38 AM
    #41
    mas32259
    mas32259 Well-Known Member
    NEPA
    2010 SR5 TRD Sport
    TRD short throw shifter, Eibach 1.6" lift coils 5100's on all corners, Ipod interface, Painted engine cover, radiator cover, skid plate, speaker grills overhead console, and added carbon fiber and chrome interior trim (Too much cheap plastic) TRD cat back, LED 3rd brake light. 100 lbs of sound deadner. Infinity ref. 6 1/2 all around. OBX pedals and shifter. DTRL mod, Alt. turn signal mod, LED's in glove box and console, LED's under dash lip and back A/C vent,Weather Tech mats. Took off antenea for wind noise
    Forget about double clutching. My Harley is 1 down 5 up there is no way you can hit neutral every shift. It has to be reved before down shifting every gear to keep from locking the rear tire. The old Tacoma (2000) had nice engine braking the 2010 has almost none.... I do miss that. The computer keeps the rpm's up between shifts.
  2. Nov 12, 2009 at 11:50 AM
    #42
    Acill
    Acill Well-Known Member
    Paul
    Port Hueneme, Ca.
    2017 TRD Offroad
    You can try letting the clutch out slowly on a down shift too. It can be bad for it over time, but it will give you a good feel of when it grabs and how the engine reacts at the current RPM. One thing I know, dont just let it all out fast, that will make it gray to soon if your in a hight RPM and you lurch.
