question for extang trifecta owners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTDTacoma, Apr 15, 2010.
  1. Apr 15, 2010 at 1:58 PM
    JTDTacoma
    JTDTacoma [OP] Well-Known Member
    08 4X4 Double Cab TRD Sport
    Is this normal to have this much play in the tonneau when latched? I can lift it a few inches all along the back when it's latched. That's at the tightest setting too- the nut is completely tightened in each latch.
    I contacted Extang and they mailed me 2 new latches for the rear but the same results. Great tonneau other than you can look inside the bed and possibly unlatch it with the tailgate up. Just wonder if others have the same issue and have figured out a way to make it more secure.
  2. Apr 15, 2010 at 3:42 PM
    nhstang
    nhstang Well-Known Member
    Brian
    Nashua, NH
    2010 TRD Sport Double Cab
    Stainless Step Bars, Extang Trifecta Tonneau
    Yup, mine's the same. Not really a cover for keeping things secure, just dry. I've had two of these--one on my 05 Tundra and now the new one. I think it's looser on this truck just because the tundra's bed rails were even all around, unlike the tacoma with the lower tailgate. Great cover though. Especially here in NH in the winter when snap or velcro type covers shrink and you can't get em back on...
  3. Apr 15, 2010 at 4:13 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Can't you adjust that by threading the latch on further?
    I have an EFX trifold, which is basically the same as the extang, and the latches are basically attached to a long bolt. The more times you rotate the latch clockwise, the higher is gets on the mount, and the tighter it latches to the bed.
  4. Apr 15, 2010 at 5:08 PM
    JTDTacoma
    No the rear ones are spring loaded and even at the tightest setting on the nut/bolt it offers too much play. The front ones tighten by turning clockwise- I guess I could always get 2 more like the front and put on the back. Just wouldn't be quick-release but would be more secure.
  5. Apr 15, 2010 at 5:10 PM
    KPT
    09 Prerunner
    No i think i'm doing a shitty job of explaining this. Let me go take a picture.
  6. Apr 15, 2010 at 5:10 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    mines the same
  7. Apr 15, 2010 at 5:18 PM
    KPT
    09 Prerunner
    Does the trifecta latch not look like this? My quick disconnects are threaded. EFX tri-fold.
  8. Apr 15, 2010 at 5:30 PM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    Nope... the new trifecta has a springloaded handles... you pull down on it to de-latch. I personally think Advantage TorzaTop design is a little better... either case, someone could cut the cover anyway so I wouldnt be too worried about it:
    http://www.youtube.com/watch?v=_FkAytTU6WM
  9. Apr 15, 2010 at 5:32 PM
    JTDTacoma
    No they aren't. I like that latch design though. Extang uses a spring latch that you pull straight down (like you're milking a cow).
  10. Apr 15, 2010 at 5:55 PM
    KPT
    09 Prerunner
    Maybe you could drill new holes in the bracket that goes in the bed rail to lower it?
  11. Apr 15, 2010 at 6:40 PM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Mine look like this and has no play at all.
  12. Apr 15, 2010 at 9:29 PM
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    mine has the same amount of play.
    when i first installed it i could lift it up and unhook them with the tail gate locked. I tightened the bolts on the spring loaded handles and it helped a little...
  13. Apr 16, 2010 at 3:44 AM
    nhstang
    Brian
    Nashua, NH
    I was ready to do that, but I realized I wouldn't be able to tighten the allen screws (they'd be behind the solid part of the bracket then.) I do wish the brackets mounted a little lower and further away from the cover though. That would help.
    But the cover stays on just fine so I wouldn't worry about it.
  14. Apr 16, 2010 at 3:58 AM
    JTDTacoma
    Yeah it stays on tight, just wish it couldn't be lifted to see what's inside. Oh well, my only complaint with it.
  15. Apr 16, 2010 at 4:22 AM
    NAYo2002
    Great Falls, MT
    Someone is lifing your tonneu to see what's inside, they already made up their mind to steal whatever in it. Soft covers are good only to keep good people honest. I wouldnt worried about it, or get a rugged hard cover.
  16. Apr 16, 2010 at 7:48 AM
    Samlin
    Samlin New Member
    Silver TacomaTRD
    Well, I'm a real newbie with my taco add ons. I am looking for a tonneau cover, something that I can put on myself, and locks. any suggestions from the experienced membership?
