Question for the lighting snobs
Discussion in 'Lighting' started by Arpatton86, Oct 1, 2019.
  1. Oct 1, 2019 at 10:12 AM
    Arpatton86
    Arpatton86 [OP] Well-Known Member
    Ontario Canadia
    2017 DCSB TRD OFF-ROAD OV TUUUUNED
    Ive had an Mori Moto HID kit installed in my truck for about two years now and I’ve been noticing the last couple of mornings that I’m starting to get a flicker in one of the bulbs. I’m thinking it’s the ballast going out but I haven’t really checked yet. I was wondering if it would be worth replacing or should I just go with the 2 stroke 2.0 or any other lighting recommendation.
  2. Oct 1, 2019 at 11:49 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Flip the bulbs and see if the flicker follows to the other side. If it doesn't then flip the ballast to see if it follows to the other side.
    crashnburn80 likes this.
  3. Oct 1, 2019 at 12:13 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep, This^. It will allow you to diagnose the specific component failure.
  4. Oct 1, 2019 at 5:29 PM
    Arpatton86
    Ontario Canadia
    Depending on what it is, would y’all replace the part either the bulb or the ballast which both are 45/50$ or go with an LED bulb?
  5. Oct 1, 2019 at 5:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  6. Oct 1, 2019 at 7:00 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Also from what I've seen on the road are no more reliable than a HID or halogen bulb.
