Question for those of you with OV Tune Dongle kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by House Forsaken, Mar 20, 2019.
  1. Mar 20, 2019 at 3:43 AM
    House Forsaken
    House Forsaken [OP] Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I picked up an ov tune kit from a member and reached out to Matt who got me started. For the record Matt is great to work with!!
    I have the older version of the tune which is the dongle kit. I found these directions, https://cdn.shopify.com/s/files/1/0...ctions_-_Discontinued.pdf?6572417600888913780 online.
    My question is, in step one is states "Select the proper flash template (p5 for ecu, p5 gearbox for TCU if needed)" which one did you select? what are the differences between those 3 options?
    Thanks in advance!!!
  2. Mar 20, 2019 at 6:07 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
  3. Mar 20, 2019 at 6:17 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    It won't really matter. If one doesn't work, select another. I think I read that Mat thought one might flash faster than another, but I can't find his post.
    I should add that I have a manual. If I had an automatic, I'd select the P5 Gearbox, since it appears to also update the TCU.
    House Forsaken[OP] likes this.
  4. Mar 20, 2019 at 6:28 AM
    Shellshock
    Iowa
    There first 2 options will flash the ecu. There’s been a few instances where one works but not the other on some trucks - either will get the job done. The gearbox option is for the TCU flash (which there isn’t one currently)
    The software is smart enough to not let you do something that will harm things. Worst case it fails and you try something else.
  5. Mar 20, 2019 at 6:41 AM
    House Forsaken
    Paul
    Thanks!!!!!!!!
