Question for those who cut their fenders & cab mounts to clear bigger tires
Discussion in 'Wheels & Tires' started by Bobber Bill, Oct 4, 2011.
  1. Oct 4, 2011 at 9:23 AM
    Bobber Bill
    Bobber Bill [OP] Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    After you cut into your cab mounts, did you box them back up with some 10 ga. sheet?
    Did you guys lift the body off and remove the bushings before welding?
    I don't want to expose the cab mount bushings to all that heat from the TIG, but I don't exactly have a way of lifting the entire body off the frame either.
    Any help is appreciated. Thanks
  2. Oct 4, 2011 at 9:25 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Didn't lift the body and welded a plate back after the chop. A year later and everything is still fine.
  3. Oct 4, 2011 at 10:57 AM
    Bobber Bill
    Los Angeles, CA
    Sweet. Good to hear. That's a pretty serious rig you've got there. I wonder if any of this morning's rain made its way to the Main Divide. I've got some brand new A/T's that need dirtying
    Ya, I'll just go back and forth with 1 inch beads
    Other than that, gotta make sure that I cut enough out to clear when the front's tucked
