Question for those who have installed Husky mud flaps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTakeover, Feb 17, 2015.
  1. Feb 17, 2015 at 6:57 PM
    TacoTakeover
    TacoTakeover [OP] Well-Known Member
    Will the 3 original OEM screws work to install the Husky mud flaps? Or do the Husky flaps have their own screws/hardware that come with them? Also, do the Husky flaps need the OEM pushpins (mine all broke when popping them out while taking the original flaps off)?
  2. Feb 17, 2015 at 7:33 PM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I believe the Huskys come with their own hardware.
  3. Feb 17, 2015 at 7:37 PM
    TacoTakeover
    I wonder if thee original screws will work if you don't have the ones the Huskys cam with?
  4. Feb 17, 2015 at 7:37 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I can confirm that they do include hardware, including clip nuts.
    I can't say how it all works out in the end - I bought a pair for my brother-in-law for Christmas, so did not install them.
  5. Feb 17, 2015 at 7:38 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    I believe the three screw holes are in the same locations.
  6. Feb 17, 2015 at 7:47 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I was able to install mine with all original hardware. Each Husky flap uses two screws and one clip, so you should be OK even after breaking a couple of clips.
  7. Feb 17, 2015 at 8:09 PM
    TacoTakeover
    So two screws and one pushpin? It looks like the Husky flaps have more than three holes though....are the other holes just not used?
  8. Feb 17, 2015 at 8:16 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    My fronts have 3 bolts & 3 push pins. Don't have the rears, can't speak to that.
  9. Feb 17, 2015 at 8:20 PM
    KenLyns
    Belly of the Beast
    My front flaps required two screws and one pushpin, as the photo shows. This was May 2012. I don't know if Husky changed the design afterwards.
    Another thing, the Husky flaps are too short to effectively shield the rocker panels from road spray. I had to add an extension. (OEM flaps, despite all the complaints, are appropriately sized for their intended function. I needed the Huskies for 32" tire clearance.)
  10. Feb 17, 2015 at 8:26 PM
    glwood6
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Got mine in 2014, so they must've added the other 2 push pin holes.
  11. Feb 17, 2015 at 8:38 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    on my husky rear flaps i used the 3 original screws... they do come with 2 clips but I didnt use them
