Question for those with a Camper Shell?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yamaha Dave, Oct 24, 2013.
  1. Oct 24, 2013 at 10:03 AM
    Yamaha Dave
    Yamaha Dave [OP] Well-Known Member
    Ok I have a really dumb question but I gotta ask. What purpose does it serve to have a pass through window on a Camper shell? I will be needing a camper shell early next year for a move and this would help me keep things secure in the back, but I'm not sure what the purpose of having a pass through other than maybe giving air or heat to my dog if I put him in the bed.
  2. Oct 24, 2013 at 10:44 AM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    No purpose I see that the tailgate (or rear canopy window) open couldn't do :confused:
  3. Oct 24, 2013 at 11:11 AM
    Madjik_Man
    Colorado Front Range
    The only time I've ever used it is when I'm hauling long 2x4s
  4. Oct 24, 2013 at 11:12 AM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    You ever try putting 10 foot PVC pipe into a shortbed truck with a shell ? I've been re-doing my hardscape and been buying long pieces of pipe and lumber. With a DC shortbed, I have to put down the pass through in my shell, slide open the rear window of my cab, so I can put long pieces of lumber or pipe through into the cab. Trust me, its a lifesaver.
  5. Oct 24, 2013 at 11:13 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    If you mean a removeable slider up front , they allow for ventilation and being able to remove it allows for cleaning the back of the cab glass without temoving the cap
  6. Oct 24, 2013 at 11:13 AM
    OZ-T
    Peter North
    British Columbia
    I use the cap racks , and carry 16' ladders and lumber :)
  7. Oct 24, 2013 at 11:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Same here, I use mine when hauling long piece of wood or pipe. I didn't get the full flip down window for cleaning the rear window of the cab but it would be nice (mine was used so I got whatever options the previous owner decided on).
  8. Oct 24, 2013 at 11:56 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I use mine for long lumber, especially finish trim that I don't want to put up on the racks. Also, as you mentioned, to allow clean air (hot/cold) to get back there for my dog when the back seat's occupied
  9. Oct 24, 2013 at 12:10 PM
    Yamaha Dave
    Thanks guys. Any other uses other than those mentioned above keep chiming in..trying to justify the purchase as well as make the truck more versatile. I don't haul lumber much anymore because I'm still a student.
    Is it feasible to sleep in the back of the bed or I'm I just crazy? Another use I'm thinking would be while commuting 4 hours back home during the weekends, if I've had a long day and I need to pull over I could catch a nap in the back or maybe that's a little much?
  10. Oct 24, 2013 at 12:17 PM
    OZ-T
    Peter North
    British Columbia
    If you plan on making a bed platform in the bed , consider a mid height cap like the Leer 180 or similar
  11. Oct 24, 2013 at 12:25 PM
    Pugga
    Massachusetts
    x2, great advice. I built a platform and the extra head room offered from the mid-rise is very welcomed!
  12. Oct 24, 2013 at 2:10 PM
    yote
    Mark
    Tacoma, WA
    I've slept in the bed of my truck many times while out weekend hunting in college. Just bring foam or self inflating hiking air mattress(es) and you'll be good to go.
  13. Oct 24, 2013 at 2:27 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    transporting fishing poles
    can leave open for air flow to the cab and bed during hot days without worrying of break-in.
  14. Oct 24, 2013 at 2:40 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    I made a doughnut type seal that frames the perimeter of the 2 slider frames. It is made of foam pipe insulation. 4 pieces glued together with mitered corners. I just stuff it in place from the inside and pretty much leave the 2 sliders open all the time. It keeps the rain out while letting AC and heat get to the back.
    The best feature is keeping dust out of the back. With the cab fan on and windows up it allows a slight positive pressure in the back. This blows air out any of the gaps (that I have not sealed) preventing any dust from coming in.
    I can drive the dustiest desert road at speed with out any dust what so ever entering the back.
    Some shells have a "lip" or "accordion boot" between the cab and shell from the factory. Some folks use a bicycle inner tube to the same end.
  15. Oct 24, 2013 at 2:48 PM
    OffroadToy
    Most shops discourage anything between the cab and canopy due to paint damage.
  16. Oct 24, 2013 at 3:18 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    I know what you mean. My first shell 30 years ago had a "lip" on the shell, no slider, just a cab slider. It chafed through the paint in no time and would squeak like crazy. This is why I came up with the pipe insulation trick. It only contacts the glass and part of the slider frames, no paint.
  17. Nov 18, 2013 at 4:39 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    I used to camp in the back of my '88 regular cab with a cap on the back. I would open the slider on the cap and open the slider on the truck, then insulate the gap with something and get the heat blazing in the truck. Helped on cold Moab and Santa Fe nights.
  18. Nov 18, 2013 at 4:42 PM
    Yamaha Dave
    ^Well I'd be afraid of falling asleep and dying of Carbon Monoxide poisoning kind of like Shane from MTV's Buckwild passed. Very tragic.
  19. Nov 18, 2013 at 4:44 PM
    CantSitStill
    FTR
    CNY
    Sorry.. Should have added, just to give it a bit of heat, BEFORE going to sleep.
  20. Nov 18, 2013 at 4:46 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I am happy I got the open shell so I can have access to the shell from the cab if needed.
