question for those with Fox
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stevenjasmin, Jan 1, 2018.
  1. Jan 1, 2018 at 7:11 AM
    stevenjasmin
    stevenjasmin [OP] Well-Known Member
    2017 TRD OFF-ROAD
    hey guys, I have been going the the fox related threads to find my answer but haven’t.
    Currently I have. 3/2 leveling kit with a center axle to fender reading of about 23 1/8 inches. I will be installing my fox 2.5 coil overs and would like to get the preload close before I install.
    Do any of you with these coil overs know about how many threads should be exposed to get a fender height of 23-23 1/2 inches
    This is for a 3rd gen.
    Lastly any of you found a successful way to adjust while on the truck?
    Thank you all and happy New Years.
  2. Jan 1, 2018 at 7:35 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    I have the Fox coilovers, it's like 8 threads per inch. I've adjusted them successfully on the truck. Take the set screw all the way out, spray it down with lube, make sure the truck is at full droop and use a 5/16 centerpunch with a cheater to turn the collar. It's much easier to do off the truck but it can be done.
  3. Jan 1, 2018 at 10:36 AM
    Haikin
    Haikin Well-Known Member
    What is the max exposed thread for the Fox 2.5s? Anyone know?
  4. Jan 1, 2018 at 10:48 AM
    eon_blue
    Azusa, CA
    I'm not sure about Foxes, but I know that with Kings you don't want to loosen the set screw too much or it'll jump threads when you turn the collar...which would be bad news if that were to happen
  5. Jan 15, 2018 at 12:38 PM
    Ten Eight Rider
    Ten Eight Rider Well-Known Member
    Central California
    2006 White Tacoma SR5 DCLB 4x4 V6
    Fox 2.5" Coilovers, Fox 2.0 Rear Remote Reservoir DSC, SPC Light Racing UCA, Wheelers Progressive 1.5" AAL, Wheelers Bump Stops, Wheelers Braided Brake Lines, Fuel Revolver 16x8, Toyo AT 265/75/16, ECGS Bushing, Energy Suspension Steering rack bushings/sway bar bushings, All-Pro Sway Bar Links, At the Helm Fabrication bumpers (front and rear), Cali-Raised LED lights, Leer Cap
    I'm also curious on this. I have Fox 2.5" with 1.5" threads showing and it only raised the front 1.5". So is it an inch for an inch?
