Question for those with the AP Standard leaf pack
Discussion in 'Suspension' started by Slowdotna, Aug 12, 2015.
  1. Aug 12, 2015 at 9:14 PM
    Slowdotna
    Slowdotna [OP] Active Member
    Sam
    2015 DCSB TRD OR in blue
    I'm looking to put a 3" lift on my '15 TRD OR. I'll be riding 90% on road and the other 10% will be mainly fireroads and riverbed trails with a tiny bit of crawling. No high speed runs across dunes and whoops.
    After reading up on it for weeks I like the characteristics of a progressive suspension so I'm looking at Fox. I'm not trying to break the bank with a King setup. I like the adjustability of the Fox components so I'd rather go this route over the Billy's or OME in case I decide to get a bit more serious with it down the road.
    Up front I'm going to put the 2.5 coilovers w/out res in extended length. I've already got All-Pro UCA's that I picked up on a group buy through here.
    In the back I'd like to use the All-Pro standard pack for its well reviewed flex and supplement them with ride rite airbags and cradles which I currently have installed. My bed is typically empty other than the occasional trip with a wheeler or a trailer, so I don't think I'd like to sacrifice the flex for the additional support of the Expo's.
    My question is which fox shocks are you guys running or recommend with the standard leaf pack?
    All-Pro recommends the 2.0 performance shock (#985-26-118) with the Expo's that support a 3.5"-5" lift.
    Will those be too long for the standard pack once it settles?
    Would the #FOX-985-26-117 be better? Its designed for a 2"-3" lift.
    From weboffroad
    985-26-118 Extended 24.80 in. - Collapsed 15.20 in. - Stroke 9.60 in.
    985-26-117 Extended 23.80 in. - Collapsed 14.70 in. - Stroke 9.10 in
    Thanks guys
    -Sam
