Question For Undercover Classic Tonneau Owners
Discussion in 'Tonneau Covers, Caps and Shells' started by Rickochet, Jan 18, 2011.
  1. Jan 18, 2011 at 5:32 AM
    Rickochet
    Rickochet [OP] Well-Known Member
    Rick
    Kentucky
    '09 Tacoma Access 2.7 4 x 2
    Added VS Wipers, Cruise Control, DRL, Undercover SE Bed Cover
    I was thinking about getting an Uncercover Classic or SE tonneau cover for my truck and have a question for someone who owns one. Does the rear of the cover overlap the tailgate which requires opening the cover every time you want to open the tailgate? If it does is this as big a PITA as I think it might be?
  2. Jan 18, 2011 at 5:42 AM
    GerhartCss
    GerhartCss Well-Known Member
    Harrisburg, PA
    08 TRD Sport
    Pioneer AVIC-X710BT w/ PAC SWI-PS, Leaf Spring TSB
    Yes, the classic does overlap the tailgate. I have not found it to be a pain in the ass but have not owned that long. It's a positive to me because it means you don't need a pop and lock in order to make your entire bed secure.
  3. Jan 18, 2011 at 5:44 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Yes, it will prevent the tailgate from opening. You can just lift the cover an inch or so just enough to open the tailgate then drop it back down. Not a big deal the couple times I've had to do it. Most of my stuff I load over the rails, so I just open the cover, and the tailgate doesn't get much use.
    I have a classic, and I'm 99% sure the SE works the same.
  4. Jan 18, 2011 at 5:56 AM
    Rickochet
    Rick
    Kentucky
    I already have a pop and lock so that is not an issue for me. I just wonder if having to mess with two latches and the top every time to open the gate is a pain.
  5. Jan 20, 2011 at 12:24 PM
    GerhartCss
    Harrisburg, PA
    08 TRD Sport
    Since they recommend you lock it every time you are driving I could definitally see it getting old if you are opening and closing it very frequently, like every time you stop the truck. The SE only has one lock on it so that might be a little better.
