Question for you Black Sand Pearl 2009 owners....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Feb 8, 2010.
  1. Feb 8, 2010 at 6:06 AM
    BSP4x4
    BSP4x4 [OP] Guest
    For those of you with an access cab who have the satellite radio antenna right above the rear brake light….do you notice anything wrong with your paint behind the radio antenna? I noticed that the paint is all worn away here….and there seems to be some wearing down on the brake light. I have never loaded anything in my bed yet so I’m not sure what caused this.
    I think it may be the antenna that changes the air flow around that area and caused abnormal wear….
    Almost looks like what a fine grit sand paper would do......thoughts?
    PICS to come later tonight!
  2. Feb 8, 2010 at 7:23 AM
    BSP4x4
    BSP4x4 [OP] Guest
    no one else having this issue?
  3. Feb 8, 2010 at 7:26 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    I have an XM antenna that has not mover since March 05 when the truck was new. I dont believe there is any paint wear.
  4. Feb 8, 2010 at 7:36 AM
    BSP4x4
    BSP4x4 [OP] Guest
    the antenna itself is not moving...I just think that there may be wind resistance around and over the back of the antenna....i'll have to get some pics up....basically what i'm asking is if anyone has any paint wear behind the antenna?
  5. Feb 8, 2010 at 8:14 AM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    Yes I understood that but my reply didn't read like I did. But yea, I have no paint wear from wind resistance behind my regular little xm antenna.
  6. Feb 8, 2010 at 8:27 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'd highly doubt wind resistance would cause it anyway... I mean if that's the case the front of the truck should be 'sandblasted' away from highway driving. Perhaps the antenna is a bit loose and vibrating against the paint, or you have some defective paint there... sounds like a dealer problem to me.
  7. Feb 8, 2010 at 8:28 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    North DFW
    07 DCSB Sport 2wd
    5100s @ 0.85, Grom iPod/Bluetooth adapter, mud flaps removed, clear turn signal bulbs, two extra D-rings, debadged, fog light anytime, OEM bed mat, Undercover classic, Falken Wildpeak A/T3W, Fumoto valve
    Wind tearing up your paint?
  8. Feb 8, 2010 at 8:29 AM
    BSP4x4
    BSP4x4 [OP] Guest
    Yeah..it's weird...the marks are about 2 inches behind the antenna....maybe i was vandalized?
  9. Feb 8, 2010 at 8:29 AM
    BSP4x4
    BSP4x4 [OP] Guest
    what about ice and snow? and or sand/salt?
  10. Feb 8, 2010 at 8:30 AM
    BSP4x4
    BSP4x4 [OP] Guest
    the only other thing i can think of is going through a touchless car wash....could that be it?
    Pics to come...i think they will clear things up a little
  11. Feb 8, 2010 at 8:41 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Powerwashers could rip paint straight off a car, especially if it was never cured properly or really weak. Still, I highly doubt a touchless caused it... but it's possible.
  12. Feb 8, 2010 at 10:08 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Mine is OK and does not have a problem.
