Question from an electrical "ra-tard"
Discussion in 'Lighting' started by AfroWookie, Jan 28, 2015.
  1. Jan 28, 2015 at 11:51 AM
    AfroWookie
    AfroWookie [OP] Active Member
    Portsmouth, VA
    09 Speedway Blue DC Sport
    Hey guys, I just order a Blue Sea aux fuse box for my truck. I also have an LED light bar on order. Since I'll be running the extra fuse box, will I need an aftermarket wiring harness? My uneducated mind says no, but like I said, I know nothing about electrical. The lighted rocker switch I got for it has 5 "pins" on it, and in my head (long story short) wire from light to switch, wire from switch to ground, wire from switch to fuse in aux box, power from battery to aux box, am I right?
    Thanks guys
  2. Jan 28, 2015 at 2:23 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    who makes the switch? part number for it?
  3. Jan 28, 2015 at 2:25 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Sounds like OTRATTW.
  4. Jan 28, 2015 at 2:35 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    You need a relay to feed the light bar. The switch will turn "on" the relay. You will need a 6ga. or larger to feed the Blue Sea fuse panel. I don't know what you mean by "wire harness". All wiring for this mod will be new.
  5. Jan 28, 2015 at 6:41 PM
    AfroWookie
    Portsmouth, VA
    This is the switch I bought
    http://www.amazon.com/gp/product/B00M5YC7Q4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    I've noticed a lot of people buy a wiring harness like this one when they install an LED light bar
    http://www.amazon.com/MICTUNING-Uni...qid=1422499237&sr=8-3&keywords=wiring+harness
    If I'm looking for constant power, is a relay really necessary?
  6. Jan 29, 2015 at 10:12 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  7. Jan 29, 2015 at 10:17 AM
    Large
    Large Red
    You don't need a wiring harness. You can just go buy some #12 AWG with some lugs and a crimper, and a relay if you desire.
  8. Jan 29, 2015 at 11:14 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    this is the way you can run it.... get a relay harness for the LED bar.
    run the harness to where it needs to go
    the relay should be close to the aux fuse block (if possible)
    mount the fuse block in a suitable location
    run 6 gauge fused power wire to the (+) aux fuse block
    run 6 gauge ground wire to the (-) aux fuse block
    pick 1 of the fused outputs and label it
    take the fuse out of the power wire to the relay harness. Pin 87 of relay
    place that fuse into the selected slot or wait until you have completed the rest of the wiring (Preferred & Safety) * make sure the fuse is the correct rating for the light bar.*
    cut off the fuse holder to the relay
    put a ring or spade terminal on the end of that wire and attach it to the fuse block selected slot
    run 2 wires through the firewall to the switch
    connect 1 wire to the "to light" terminal on the above picure
    connect the other end of that same wire to the relay for pin 86. this provides the power to activate the relay.
    connect the 2nd wire to the ground side of the switch.
    connect the other end of that same wire to the grounding block on the fuse block.
    *You can ground the switch in the cab and not use this wire*
    pick a switch 12volt source in the cab to power the lighted switch and active the relay
    run a fused wire from switch source to the "to battery" pin of the switch
    connect wires to switch
    wire the switch as seen in the picure
    connect the LED bar power wire to pin 30 on the relay
    connect the LED bar ground wire to a chassis ground or aux fuse box ground block
    connect relay pin 85 to ground
    reinstall fuse
    check for operations / flip the switch.
    Let there be light
