Question Halo headlights
Discussion in '2nd Gen. Builds (2005-2015)' started by Ghumps, Jun 30, 2012.
  1. Jun 30, 2012 at 2:41 PM
    Ghumps
    Ghumps [OP] Well-Known Member
  2. Jul 1, 2012 at 10:07 AM
    Ghumps
    bump
  3. Jul 1, 2012 at 6:43 PM
    Ghumps
    bumpity bump
  4. Jul 3, 2012 at 10:35 PM
    Ghumps
    bump
  5. Jul 3, 2012 at 10:43 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    CCFL is Cold Cathode.
    That is what is pictured in the listing.
    I suspect that the base package includes only the LED strip around the bottom outside and no "halo" around the lamps.
  6. Jul 5, 2012 at 7:43 PM
    Ghumps
    sooo should i Upgrade to it for $20.00?
  7. Jul 5, 2012 at 7:52 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I assume that the downgraded version have LED's in the Halo(2 facing up, 2 facing down to shine around the ring), like mine have. The CCFL would be 1 or 2 Cathode tubes around the rings.
    The Cathode Tubes give a solid color like neon where the LED's tend to fade the farther around the ring away from the leds.
  8. Jul 5, 2012 at 8:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    eBay projectors suck.
    eBay projectors with HIDs suck less.
    Buy a spare set of stock headlights and a full FX-R projector kit and do a proper retrofit.
    You can even do a CCFL halo if you like that (I don't care for it).
  9. Jul 5, 2012 at 9:11 PM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    how come this is in 2nd gen builds? pic for it didn't happen!
  10. Jul 5, 2012 at 9:23 PM
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    You can get this same pair much cheaper, and they are all the same. Yes they leak unless you go around them with some sealant. I had them on my truck until I did my retrofit, they are not bad. I def suggest putting some HIDs in them, the stock light output isnt super.
  11. Jul 17, 2012 at 9:44 PM
    The Silver Bullet
    The Silver Bullet Member
    07 PreRunner TSS
    Pioneer Head Unit LED Foot-well lighting Two 10 in subs halo headlights
    I have these same headlights and wanted to install some HID's in them but i heard some crap about the HID's possibly messing up the inside of the headlight assembly? Any info or suggestions?
  12. Jul 18, 2012 at 5:40 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    HIDs will mess them up if you go with a 55w, but whether you do or not, eBay projectors are terrible. Output from HID will be no better than stock.
  13. Jul 19, 2012 at 1:34 PM
    The Silver Bullet
    07 PreRunner TSS
    Thanks for the info. If i went with a 35w ballast would they work out?
  14. Jul 19, 2012 at 4:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And then when the light output and pattern is shit, come back on TW and complain that you spent $250 on headlights that look like shit and then find out that your $75 HID kit is worthless for a real retrofit so you have to start over at square-one.
  15. Jul 23, 2012 at 8:41 PM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    do you guys know of anyone who's retrofitted any trs HID kit's into dual halo projectors?
    I mean actually replacing the projectors also?
    I like the look of my 3rd gen dual halo projectors.....and yes they were bought from ebay.....I do like the look better than the stock retrofit, imo
    Just curious if it is possible
  16. Jul 23, 2012 at 8:44 PM
    Rascal737
    Oliver
    Abbotsford, BC
    this is my current set-up....i installed the switchback dtrl's from csjumper2003 and will probably change out my corner lights to led's too
  17. Jul 23, 2012 at 8:45 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    here is a picture of the cut off from this style of light it may change your opinion on them. the other pic is of my fx-r retrofit its the only thing i had to compare them against.
    edit: added another picture of my lights closer to a wall about 25 feet if that so basically this is really only one projector lighting up the entire length of my house at 25 feet. my truck is on the grass at the other end of the house btw.
  18. Jul 23, 2012 at 8:49 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Check with user Moose1988
    It looks like he retrofitted a set of Morimoto H1 projectors into his eBay lights.
    Haven't seen a detail thread on how it was done.
  19. Jul 23, 2012 at 8:50 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    This?
    THAT is the pattern from these projectors?
    Yikes. That looks like shit!
  20. Jul 23, 2012 at 9:07 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    :eek::eek::eek::eek:
